Old 03-26-2023, 11:49 PM #1
prybar's Avatar
prybar prybar is offline
prybar is on a distinguished road
prybar's Avatar
Elocker retrofit
Hi all,
I picked up a locked rear end from a first gen Tacoma this weekend for a good deal, with the intention of sticking it in my rig for a quick and dirty locker solution. After looking closely at the axle housing, I noticed it had been bent in a collision. Damn. Still a good deal so I scooped it anyways.
So I plan to use my axle housing. I went to look up the Sonoran Steel writeup, but I can't find it - I get a "page not found" message.
Any chance anybody has this saved somewhere? Or if anybody remembers the steps and maybe has some photos. I know I need to drill/tap and build up some metal with weld, just would like to look at the writeup before I start for some peace of mind. Thanks.
'99 Limited, 260k
prybar is offline   Reply With QuoteReply With Quote
Old 03-27-2023, 12:36 AM #2
the_welfare_wagon's Avatar
the_welfare_wagon the_welfare_wagon is offline
Real Name: Rich
the_welfare_wagon will become famous soon enough the_welfare_wagon will become famous soon enough
Real Name: Rich
8" Rear Axle Toyota E-Locker Retrofit Question | IH8MUD Forum
This should help. Has a photo as well as links to other sites covering the issue
96 Limited: 380k+ 255/85s Geolander MTs, Ironman Nitro 2" lift, Toytec 9602HD W/FJZ80 Shocks
the_welfare_wagon is offline   Reply With QuoteReply With Quote
Old 03-27-2023, 10:12 AM #3
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Originally Posted by prybar View Post
Hi all,
Tacoma rear axle housing won't work anyways unless you convert to rear leaf springs. If you are using a non locker axle housing you'll have to cut out the 3rd member opening for the locker 3rd to fit, and drill/tap new holes for the 3rd member bolt pattern change.
axle , deal , good , housing , writeup
CroMo axles wont fit elocker retrofit? Scotty_h 3rd gen T4Rs 28 09-10-2018 05:25 PM
Elocker retrofit and regearing tS_kStin 3rd gen T4Rs 27 04-03-2017 12:13 PM
Choose elocker or retrofit? McFinnigan 3rd gen T4Rs 30 03-11-2015 01:33 PM
Elocker retrofit dereky 4th Gen T4Rs 2 02-26-2015 01:43 AM
Elocker retrofit wiring harness cj80cruiser 3rd gen T4Rs 4 06-22-2013 04:16 AM
