Old 03-29-2023, 12:43 PM #1
jross20's Avatar
jross20 jross20 is offline
jross20's Avatar
Has anyone in the community tried any "Shift Kits"?
So I meant to post about this a while back but it was one of those things I just forgot about.
I've seen that there are some "shift kits" for our A340's and was curious if any users here have ever personally used them. I'm interested in the idea of the ones that speed up shifts since I presume this would A, feel awesome, and B perhaps reduce wear from slipping. I've seen ones like the Trans go and a few others.
Anyone have history with any of these? Are they good, bad, meh, snake oil, etc.
Old 03-29-2023, 02:16 PM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Have you looked through the forum yet? There's several about the transgo shift kit: https://www.google.com/search?q=site...t=gws-wiz-serp
Old 03-30-2023, 08:22 PM #3
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Yes, I have the TransGo HD kit on the truck shift settings. It pairs well with full synthetic fluid, on conventional fluid the shifts are a bit jarring. I did it for a specific purpose for a specific goal for my 4Runner. I doubt the longevity benefits are all that great and I did also have one of the springs in the shift kits break but thankfully didn't find its way out of the accumulator piston. My transmission failed anyway but it wasn't because of too much heat at least.
The install is not for the faint of heart. You'll be making some irreversible changes that cannot be undone except by replacing the valve body. Getting a 2nd valve body and installing the kit on that one would be what I'd do if I did it again. In fact, I did have a second valve body but it was from and 02 so it wasn't compatible but I did lose a check ball so I stole one from the 02 and it saved me from a real headache.
326WHP 347TQ
Old 03-30-2023, 09:04 PM #4
Does your trans have a cable going to it? If so is it adjusted properly.
That cable controls line pressure and the more pressure the firmer the shifts.
Old 03-30-2023, 10:54 PM #5
KPOffroad KPOffroad is offline
KPOffroad is on a distinguished road
One of my buddies is running a TransGo shift kit from Ebay. We did all the work ourselves and it 100% made a difference. It slips less and shifts faster as well. If you're brave enough to dive in to your trans and drill some irreversible holes then I say go for it!
KPOffroad is offline   Reply With QuoteReply With Quote
Old 03-31-2023, 08:07 AM #6
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
That's what I did. I just adjusted the cable slightly tighter. Then I turned on ect PWR so the shifts more aggressively. Good enough for me...
Old 03-31-2023, 10:45 AM #7
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Old 03-31-2023, 02:41 PM #8
Real Name: Jerod
Real Name: Jerod
Originally Posted by mtbtim View Post
Where was this 5 years ago!!
This'll help others avoid the mistakes that I did, thanks for filming this.
326WHP 347TQ
Old 04-01-2023, 02:07 AM #9
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Sean and his buddy Chris filmed it not too long ago, maybe a year.
Old 04-01-2023, 09:07 AM #10
jross20's Avatar
jross20's Avatar
Well look at that, I did search a while back but I don't really remember seeing anything, I must have been searching the wrong terms or something.
That difference with the fluid type is interesting. Honestly I've never been a fan of using newer, synthetic, thinner, fluids in older transmissions because I had the mindset of it was designed for something thick, not thin. Etc.
When you say jarring, do you mean harsh or just very firm?
You know I fiddled with the cable a little bit, but I've obviously been wondering if after 23 years the cable has stretched out because if I set it to what the book says, it definitely doesn't feel right. But at the same time, I'm a bit too afraid to set it much tighter than I have it now. Could anything be damaged if it's too tight, too much pressure?
I will say that I will definitely be using a local guy that I trust for this as transmission is definitely not my forte... Lol!
I didn't want to quote reply to absolutely everything because otherwise this single post would be super long but I do appreciate everybody's feedback. Definitely helps
Old 04-01-2023, 03:45 PM #11
Real Name: Jerod
Real Name: Jerod
It would be so sharp of a shift when cold from 1st to 2nd that it made the whole dash jolt and everyone in the 4Runner would feel it. It was harsh. Once I put synthetic in it is as smooth as before I did the valve body kit. I highly recommend switching fluid types if you do.
326WHP 347TQ
Old 04-01-2023, 04:26 PM #12
jross20's Avatar
jross20's Avatar
Wow yeah that sounds like it's too harsh. Thanks for the info. You said you used the "truck" setting right?
Old 04-02-2023, 09:17 PM #13
Real Name: Jerod
Real Name: Jerod
Yes. I have never met someone who installed the "race" setting and enjoyed it.
326WHP 347TQ
Old 04-03-2023, 05:11 PM #14
phattyduck phattyduck is online now
I've been in a different vehicle with a 'race' built auto trans (manual shifting, etc.) and it was not something I would do on the street. And not in 4LO while offroad either!
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
phattyduck is online now   Reply With QuoteReply With Quote
kits , reduce , shift , shifts , wear
Feasibility of a "J"-Shift to Multi-Mode Transfer Case Swap Diagram14 3rd gen T4Rs 18 01-21-2022 12:55 AM
going with a daystar spacer lift, questions on 1.5" vs. 2.5" kits and possible issues 2k1 3rd gen T4Rs 27 10-16-2015 01:21 PM
'88 4Runner-Tranny Fluid "burping" out of shift lever hole akalaka Classic T4Rs 2 10-11-2010 11:26 PM
"...designed for specific manufactured lift kits.." T?@\7 General Discussions 13 07-01-2010 10:11 PM
3"-4" lift kits for a '99 sr5? Recommendations? D-Mc 3rd gen T4Rs 5 04-12-2010 09:24 PM
