Originally Posted by jonnyd42
I replaced my radiator with a new OEM one, but don't have an external cooler. I do have an OBDII reader that can read out the trans temp. It never goes above 200, even under load. Typically 180-200 F range.
That's good you did the radiator replacement. 200 is pretty warm I'd say, but you mentioned going up and down hills in Washington. I'd consider throwing in an external transmission cooler. You have a few options. Hayden, B&M, etc. You could run the B&M 70268 or the 70264 (larger than the 68) and see if maybe lowering the overall temps of the fluid has any type of affect on it overall.
Sent from my SM-S908U using Tapatalk
