Old 04-04-2023, 05:18 PM #1
Madarasskishbosh Madarasskishbosh is offline
Madarasskishbosh is on a distinguished road
Clearing CEL Light
Hey everyone,
I have a Check Engine Light as well as the two VSC lights on. Codes were P0440 and P0442. Basically just a fuel/evap leak. I think I might have fixed the issue. I can’t clear the codes because I don’t have a scanner myself and it’s like a 30 minute drive to the nearest scanner (lol).
If I disconnect the negative terminal of the battery will this get rid of all 3 lights?
Is there some other way to do this? TIA.
2001 Limited 4WD.
Madarasskishbosh is offline   Reply With QuoteReply With Quote
Old 04-04-2023, 06:14 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Need to use a scanning tool to clear it.
Sometimes auto parts will scan and clear it for you. If you don't have the tool...
Old 04-04-2023, 07:51 PM #3
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
I got a cheapo $17 one online to check for smog data readiness and to read and clear CEL codes. No good reason not to have at least one of those. I have a fancier dedicated unit but I can loan this out to friends and not give a damn what happens to it.
Clearing CEL Light-obdii-jpg
258K - Y2K/E - Clock still works
Old 04-04-2023, 10:26 PM #4
Rushthezeppelin Rushthezeppelin is offline
Rushthezeppelin has a spectacular aura about Rushthezeppelin has a spectacular aura about Rushthezeppelin has a spectacular aura about
Sounds like a great excuse to get code checker. Either a standalone unit or a BT + Torque Pro. All sorts of nifty things you can do with the latter option.
'98 SR5 5 Speed
Rushthezeppelin is offline   Reply With QuoteReply With Quote
Old 04-05-2023, 12:25 AM #5
BN-2B's Avatar
BN-2B BN-2B is offline
BN-2B is on a distinguished road
BN-2B's Avatar
CEL yes
Disconnect the negative terminal for an hour or overnight and the CEL will be cleared. VSC is beyond my ‘97 comprehension. Anyway, Bluetooth scanners are excellent.
'97 5VZ-FE 4x4 Anthracite 'unmarked'. 205k. Work in progress.
OME 880/90004, 890/60073. BFG KO2 265/75/16.
Siblings: '90 Trooper V6 & '80 CJ5 IL6
BN-2B is offline   Reply With QuoteReply With Quote
Old 04-05-2023, 01:03 PM #6
It'll take about 3 seconds to clear the code...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 04-05-2023, 01:40 PM #7
Real Name: Blair
Real Name: Blair
Yep. The longer method however clears useful data that will need to be reacquired over time. Sometimes if helps for the system to relearn patterns, but i lost my cat readiness data a month ago and it still hasn't set the readiness flag and I have followed the drive patterns from Toyota a few times.
Old 04-05-2023, 02:44 PM #8
Ph03n1x24's Avatar
Ph03n1x24 Ph03n1x24 is offline
Real Name: Mark
Ph03n1x24 is on a distinguished road
Ph03n1x24's Avatar
Real Name: Mark
Pull the negative battery cable for a few minutes and it will reset, clearing the codes. (10mm)
I grabbed this el-cheapo special off Amazon $25 and it's a great addition to the `Yota tool box.
MOTOPOWER MP69033 Car OBD2 Scanner Code Reader Engine Fault Code Reader Scanner CAN Diagnostic Scan Tool for All OBD II Protocol Cars Since 1996, Yellow
Amazon.com
Good luck!
2005 Toyota 4Runner Sport Edition 4.0L 6cyl 5A | 5th Gen TRD wheels w Dunlop 265/70R17 113 S Tires | CKAuto 2" Hub Centric Wheel Spacers | 3" Lift + 1" leveling kit | Pro FOX Coilover Shock Suspension Kit | Deleted Hydraulics | Retrofit LED / USB 3.0 | PC38 Pedal Commander | Alpine iLX-w650 w KTA450 | Kicker KS Series 6"x9" 3-way - CS Series 3/4" dome tweeters - KS Series 6-1/2" 2-way | Hifonics BXX1200.1D 1200W RMS 1 Ohm amp | Dual JL 10w6v2's |Q box 50hz
2011 Toyota 4Runner SR5 - Soundproofing | HU & Speaker Upgrades
Ph03n1x24 is offline   Reply With QuoteReply With Quote
Old 04-05-2023, 05:08 PM #9
Romeo1's Avatar
Romeo1 Romeo1 is offline
Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice
Romeo1's Avatar
Clearing CEL Light
I have a fancy laptop setup (old but works still) but I'll be honest, I like my blue driver a lot better. It's just so nice to just pull your iPhone out and clear code that way and see what's going on.
I think a blue driver dongle is like 100 bucks or something.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
Romeo1 is offline   Reply With QuoteReply With Quote
Old 04-06-2023, 01:45 PM #10
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
Hey everyone,
2001 Limited 4WD.
There's a manual procedure to clear codes if they have actually been resolved. Via DLC with jumper wire, enter diagnostic mode by jumping the proper pins and hit the brake 8 times within five seconds of turning ignition to on position.
Jakeepoo3 is offline   Reply With QuoteReply With Quote
Old 04-06-2023, 02:20 PM #11
Ph03n1x24's Avatar
Real Name: Mark
Ph03n1x24's Avatar
Real Name: Mark
Glad someone chimed in that knew the steps for THIS solution as I could not remember.
Thanks!
Old 04-06-2023, 02:27 PM #12
Jakeepoo3's Avatar
Jakeepoo3's Avatar
Thanks!
No problem make sure you confirm that I didn't miss a step. It's been awhile and my memory sucks. I believe the procedure is listed in the FSM. You won't need to get involved with the initialization and learning process with this method.
codes , light , lights , scanner , terminal
Clearing Radio Presets CutthroatSlam 5th gen T4Rs 10 05-19-2019 10:40 PM
Clearing Programmed Keys powerone1 4th Gen T4Rs 1 11-08-2012 05:21 PM
Clearing things up... bulger22 3rd gen T4Rs 3 09-26-2010 10:42 AM
Battery and Clearing Codes, etc. T4RME Maintenance/Detailing 1 04-19-2010 04:42 PM
Clearing 285's w/o using spacers... wonder371 Off-Roading 0 08-22-2006 04:17 PM
