Old 04-06-2023, 06:23 PM #1
peeeeetey peeeeetey is offline
peeeeetey is on a distinguished road
1998 limited vz5 motor has misfire at 2500- 3000 rpm
I have a 1998 4Runner Limited with the vz5 engine vin code N with 180 k miles and has a misfire between 2500 and 3000 rpm. We took it to the local Toyota dealer and they said that the "bottom end" was messed up and suggested a used motor. I know these motors can go way longer. I have like everybody else gone to YouTube as my first source and found nothing to do with my problem. The tech report from Toyota did mention that the crank sensor looked messed up no details. The motor got new plugs and is running a little better but not where it needs to be. The timing belt is at 100k and it is time.. Anybody think this would me a good time to replace the sensor and the bottom pulley to eliminate that end of the mystery? Just grabbing at straws to see what works.
peeeeetey is offline   Reply With QuoteReply With Quote
Old 04-06-2023, 10:11 PM #2
Twisted Sid's Avatar
Twisted Sid Twisted Sid is offline
Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about
Before doing the belt and other components, I'd scan it for codes and then do a compression and leak down test. Those 3 things will tell you alot of info
'99 4Runner SR5: 5VZ, 2wd, AT, 400k+ club
'94 Pickup: 2wd, 22RE, 5spd, (3RZ swap in progress)
Front: Total Chaos Uniball Kit, Fox 2.5 8'' coilover
Rear: Deaver F67 Leaf Springs, Fox 2.0 14'' Reservoir Shocks, E-locker Axle 4.88 Gears 33x10.5 BFG ATs
Twisted Sid is offline   Reply With QuoteReply With Quote
Old 04-06-2023, 10:15 PM #3
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
Replace the sensor, sure. You may want to consider replacing the coil packs as well. Ignition coil. Whatever they're called for our trucks. These: More Information for DENSO 6731201
Sent from my SM-S908U using Tapatalk
Old 04-07-2023, 04:03 AM #4
I agree with checking the ignition coils and a compression test will help tell the overall health of the engine.
Old 04-08-2023, 10:04 AM #5
Thanks for the ideas. I just ordered a set of coils. keep ya posted!
Old 04-08-2023, 10:53 AM #6
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
"bottom end messed up" is not a diagnosis you want to hear, they would have needed to remove the oil pan and inspected crank bearings to determine that, unless the crank has walked or play in it. Maybe the crank rotor is damaged or the crank sensor is damaged, and perhaps due to excessive wear in the bottom end, but I would want to see it before throwing a motor at it.
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 04-08-2023, 11:20 AM #7
He could drain the oil. If bearings or thrust bearing are wiped it should show up in the oil.
Old 04-08-2023, 11:21 AM #8
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
These engines are not known for lower end issues. Unless a PO ran the engine out of oil in the past..
Old 04-08-2023, 12:01 PM #9
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
Had a very similar misfire problem, what the history on your plug wires & boots?
Old 04-08-2023, 05:53 PM #10
HiLife HiLife is offline
And if he needed to go deeper, op could do a oil analysis through Blackstone Labs. That will see parts smaller than the eye can see.
Between oil analysis and a compression check, and if need be a leak down test...that will give you a good health check on the motor.
end , limited , motor , time , vz5
1998 4Runner SR5 4x4 Automatic w/ Elocker 240k Miles needs repair - Portland OR $3000 Silver.T4R For Sale: Vehicles 4 02-02-2022 01:36 AM
1998 3rz #4 continues to misfire, tried everything Please Help? VincentGsrq 3rd gen T4Rs 12 12-26-2021 08:46 PM
1998 4Runner P0303 Cylinder #3 Misfire? bnag0 3rd gen T4Rs 1 12-02-2014 02:13 PM
Random Misfire - 1998 SR5 3.4V6 Mopar_Mike 3rd gen T4Rs 4 02-20-2014 03:37 AM
