Originally Posted by TheDurk
I installed one of those kits--I forget which one--and the instructions ended up with the blinkers switched left for right. The only way to make it work was with the controller on the passenger side, instead of on the driver's side where the factory set up had it.
Yes, some of the kits sit driver's side, some passenger side. My '97 parts truck had it passenger side, my '99 OEM (dealer/port installed) was driver's side, my current aftermarket is passenger side, etc.
You need to pull back both sides to install anyway (need signals from both sides), so it doesn't really matter either way.
You'll be all good with a new trailer converter.
'99 4Runner SR5 Auto -
4WD swapped
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
