Old 04-12-2023, 11:40 AM #1
Tin Ark Tin Ark is offline
Tin Ark is on a distinguished road
99 SR5 and Hopkins 43415 Plug-In Simple Vehicle Wiring Kit questions
New to me 99 SR5 and my boat trailer lights are not working at all and the trailer lights are absolutely good. Does not appear to have the factory tow package and it was a port installed option and the lights spliced into the 10A fuse in the engine bay. I am picking up a multimeter this afternoon but this is clearly a common issue. If I pickup the Hopkinss 43415 wiring kit and follow their instructions, will I be whole again ? I don't see a controller on the drivers side anywhere and traced the 4 pin wiring hardness from the inside of the truck to the hitch. I am NO electrical wizard but I want to fix this so I don't get tagged with a ticket.
Thanks
Tin Ark is offline   Reply With QuoteReply With Quote
Old 04-12-2023, 12:30 PM #2
2-Skinny 2-Skinny is offline
2-Skinny is on a distinguished road
I used a module like the Curt 56196 to replace the Toyota module that is behind the driver side trunk panel. Cheaper for sure, just use your meter to confirm what each wire is doing and wire it the same way.
2-Skinny is offline   Reply With QuoteReply With Quote
Old 04-12-2023, 12:53 PM #3
Thanks I just checked with a meter no juice from trailer plug out to the plug harness which I figured was the problem
Old 04-12-2023, 01:17 PM #4
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
I installed one of those kits--I forget which one--and the instructions ended up with the blinkers switched left for right. The only way to make it work was with the controller on the passenger side, instead of on the driver's side where the factory set up had it.
My Backyard Frame Swap
Old 04-12-2023, 03:57 PM #5
phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future
Yes, some of the kits sit driver's side, some passenger side. My '97 parts truck had it passenger side, my '99 OEM (dealer/port installed) was driver's side, my current aftermarket is passenger side, etc.
You need to pull back both sides to install anyway (need signals from both sides), so it doesn't really matter either way.
You'll be all good with a new trailer converter.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 04-12-2023, 09:08 PM #6
brillo_76's Avatar
brillo_76 brillo_76 is online now
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Yes the kits use the opposite side then the factory state side installed ones. [ factory drivers] rear light aftermarket [ passenger side] rear light.
brillo_76 is online now   Reply With QuoteReply With Quote
Old 04-12-2023, 09:12 PM #7
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I am almost certain mine was a hopkins. Passenger side hook in. As the darn thing burnt up again. I get to change it again. In the plus side at least when they fry they don't take out the rear lights just the trailer plug.
Be even better if they had reset circuit instead of burning up.
Old 04-13-2023, 09:10 AM #8
Thanks y’all good point on passenger side I found a YouTube video and it was installed on the passenger side now I now why. I’m waiting on Amazon to deliver it today.
Old 04-14-2023, 10:59 AM #9
So install done but driver side no bueno not working at all and pretty hard to screw up connections. Passenger side is perfect and I installed ground on passenger side clearly. Any idea on what to check before I return it ?
Old 04-15-2023, 08:18 AM #10
I called Hopkins and they were not much help. When I had issues with a different trailer last year one light didn't work and it turned out to be a bad ground. I went into the frame of the truck so my ground is good. Guess I will return it Monday for a different one. Annoying is not the word LOL.
Old 04-15-2023, 08:38 AM #11
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Which side did you install it on? Passenger or driver. As I think they are Passenger install only.
When they burn up that's what happens. You loose a side etc.
However, verify it's not your trailer as that can be having issues and not the hopkins box.
Old 04-15-2023, 08:51 AM #12
Thanks, the trailer lights are brand new LED lights and I know they are good. I installed it on the passenger side per directions. Hopkins box is new from Amazon so I will return it and get a new one.
Thanks much
kit , lights , sr5 , trailer , wiring
A Couple (hopefully) Simple Questions... MxwlT4R99 3rd gen T4Rs 1 01-19-2015 07:26 AM
Hopkins Vehicle Wiring Kit? Kung General Discussions 6 04-30-2012 01:13 AM
Brand new owner with a few simple questions shomann 4th Gen T4Rs 6 05-15-2011 05:00 PM
Few (hopefully simple) Questions kylextrisler Classic T4Rs 4 10-11-2006 07:59 PM
