04-13-2023, 05:05 PM
Original 2002 Sport Edition Wheels?
Hi all - I have a 02 Sport Edition and would like to put on original looking wheels. I have found some refurbished wheels - OE/OEM part number 4261135190 and Manufacturer Part Number 4261135181. Does anyone know if these are the correct wheels? Also which center cap and lug nuts were used? Attached a photo. Thanks.
04-14-2023, 12:08 AM
@ infamousRNR
might know the answer to this, I know he was looking for all kinds of OEM rims a few years ago so he might have gathered enough info to tell you
1998 4Runner Limited 4WD w/Rear Locker
281k Miles
Build Thread
04-14-2023, 12:18 AM
Real Name: Jon
Real Name: Jon
Those rims look exactly like my 2001 sport rims and a spare set. I bought out of CA when I found out all 4 of mine were bent..
Center caps are different than old style 1996 through 2000
They use the same lug nuts as the aluminum alloy wheels do.
Steel rims use different lug nuts then the alloy rims do..
04-14-2023, 07:17 AM
They sure do look like '01s, not sure if '02s differed.
04-14-2023, 08:31 AM
Those are the exact rims on my 02 Sport and I have no reason to think it's anything but OEM.
16" right?
Jason
~ Jason
2002 4Runner 4wd SR5 Sport Edition
+ many other cars
04-14-2023, 09:18 AM
Real Name: Mark
Real Name: Mark
Rim street name is coke bottle rims, came on 01-02's all of them. Look close at jgue467's center caps they are specific to MY's, lug nuts are same as any, any center cap fits.
04-16-2023, 06:05 PM
I think these are a great looking factory rim. If anyone has a set of these for sale in good condition, I’d buy them. Preferably someone in the PNW.
04-16-2023, 06:14 PM
Originally Posted by RodrickHeffley
@ infamousRNR
@ SaanichRunner
not sure about part numbers but as far as looks go those are them...
01-02 limited edition 4runners typically came with those "coke bottle" wheels...
IMO, the 5-star rims look better if you're going to spend money on buying new wheels... but that's me.
- Sean
1998 Desert Dune Toyota 4runner Limited 4x4 w/ factory e-locker
2000 BLACK Toyota 4runner Limited 4x4 w/ factory e-locker Build Thread
2002 Thundercloud Metalic Toyota 4runner Limited 4x4
Build Thread
04-19-2023, 12:04 PM
Thanks all for the input. I spoke to the local Toyota dealer and they said that those rims were obsolete. Toyota Parts Direct has them on their site but when I inquired, they said that they were no longer available. So, unless I can find some used ones in good shape I am out of luck.
@ infamousRNR
- which 5-star rims are you referring to? Do you have a picture or part number? Thanks.
04-19-2023, 12:19 PM
Real Name: Mark
Real Name: Mark
Coke bottles can be found used way cheaper sold mine for $250.
This the 5-star bought last month caps & lugs $250 all needed was cleaning n waxing.
04-19-2023, 12:54 PM
Those look great.
04-20-2023, 11:38 PM
Not totally true, SR5s came with the 5 stars as an option. My 01 had them factory. Coke bottles were standard on Limited and Sport editions.
5 stars I think look better, but if you want total OEM I get keeping the coke bottle rims.
2008 Toyota 4Runner Limited 4x4 - Salsa Red, DD, Mostly Stock, 89k miles
2001 Toyota 4Runner SR5 4x4 - Not Stock, Lifted, Armored, 291k miles
1987 Toyota Supra N/A - Stock, 2nd Owner, 92k miles
04-21-2023, 11:35 AM
Real Name: Mark
Real Name: Mark
Guess I hit that with too a broad brush. I've looked at some base models that had them could of been swapped
for same reason I went 5 star, preference what you like.
