Old 02-26-2024, 01:40 AM #16
G_Raw's Avatar
G_Raw G_Raw is offline
G_Raw has a spectacular aura about G_Raw has a spectacular aura about G_Raw has a spectacular aura about
G_Raw's Avatar
Originally Posted by Kokomodo View Post
First, 2wd to 4wd...respect. That sounds like a lot of work. Second, it seems to be the consensus that due to wear and the need for precise alignment of the bearings to races, pressing them out is preferred. I"m going to give the mechanic (who has a great reputation) the benefit of the doubt and assume there was something wrong (rust?) with the bearing/hub/knuckle. However, this sounds like something I need to learn to do.
Oh! I'm just now figuring out that my previous experience is all on my 2WD F150...which uses rotors with pre-installed races. In the past, I've simply replaced the bearings when I replaced the rotors. With the 4Runner (4WD) the knuckle and hub assembly is completely different, and uses pressed in bearings. Okay. Now I'm tracking.
Also I did non-ADD conversion not ADD like most 3rd gens. So I can't compare bearing not torque specs. But I will tell you non-ADD wheel bearing nut torque spec is absurd at like 220ft/lbs. Our wheel bearings are no joke.
99 Limited: 4wd conversion, OME 883/891, Built Right UCAs, Armored and winch up front, 285's with 4.88s and dual locked.
G_Raw is offline   Reply With QuoteReply With Quote
Old 02-26-2024, 03:32 PM #17
The manual hub bearing setup is nearly the same as the 2WD setup. The 2WD just has a cap on the back and the hub is solid in the center, so no spot for the axle and no holes to mount the locking hub. The ADD bearings/hub are held together with the axle and axle nut, like a big version of many FWD Japanese vehicles.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 09-02-2024, 11:25 PM #18
Karsyr06 Karsyr06 is offline
Karsyr06 is on a distinguished road
Originally Posted by Gerdo View Post
Where are you located?
I have two that I don’t need.
Do you still have them?
Karsyr06 is offline   Reply With QuoteReply With Quote
interchangeable , knuckle , part , replacement , tacoma
4th Gen Knuckle on 3rd Gen? bigten4R 3rd gen T4Rs 2 06-07-2018 10:28 AM
Steering Knuckle Replacement.. jstutz101 4th Gen T4Rs 13 03-28-2017 09:50 PM
85 Knuckle Service - Fill the knuckle 3/4 with grease? 1st Gener Classic T4Rs 3 02-06-2015 02:35 PM
Steering knuckle replacement Jack08520 3rd gen T4Rs 2 08-07-2014 04:56 PM
Taco steering knuckle vs. 4Runner steering knuckle ryankmasuda 3rd gen T4Rs 6 08-27-2012 09:05 AM
