Old 04-17-2023, 06:01 PM #1
Gone4broke's Avatar
Gone4broke Gone4broke is offline
Gone4broke is on a distinguished road
Gone4broke's Avatar
Gas light always on?
So i just changed my dash lights, didn't touch the gas warning light or anything else but now my gas light is always on even though I'm at over a half a tank. Anyone else experience this or know where I would start to fix it?
Sent from my Pixel 7 using Tapatalk
Gone4broke is offline   Reply With QuoteReply With Quote
Old 04-17-2023, 06:03 PM #2
Gone4broke's Avatar
Gone4broke's Avatar
Originally Posted by Gone4broke View Post
So i just changed my dash lights, didn't touch the gas warning light or anything else but now my gas light is always on even though I'm at over a half a tank. Anyone else experience this or know where I would start to fix it? 1997 5spd 5vz
Old 04-17-2023, 06:08 PM #3
phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future
What year?
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 04-17-2023, 06:34 PM #4
Gone4broke's Avatar
Gone4broke's Avatar
Originally Posted by phattyduck View Post
What year?
1997 SR5 5 SPD 5vz
Old 04-17-2023, 06:37 PM #5
RodrickHeffley's Avatar
RodrickHeffley RodrickHeffley is offline
RodrickHeffley has a spectacular aura about RodrickHeffley has a spectacular aura about
1997 SR5 5 SPD 5vz
Did you replace more than three lights with leds in the cluster? The one on the far left should be left as an incandescent, I found out the hard way when I had the same issue you are.
1998 4Runner Limited 4WD w/Rear Locker
🥳 280k Miles 🥳
Build Thread
RodrickHeffley is offline   Reply With QuoteReply With Quote
Old 04-18-2023, 01:30 PM #6
1997 SR5 5 SPD 5vz
Well, there's your answer. The gas light on the '96-'98 years needs to be incandescent. The sensing system requires the bulb filament to work correctly.
'99-'02 use a different sender system and can use an LED.
Old 04-18-2023, 02:01 PM #7
gamefreakgc's Avatar
Real Name: Jerod
gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of
Real Name: Jerod
Would that have to do with the LED's not providing any resistance in the wiring? I replace a few bulbs in the dash other than the backlights with no issue but I didn't touch the CEL as I wanted it to be orange and noticable.
326WHP 347TQ
Old 04-18-2023, 05:46 PM #8
The 'old-school' way that Toyota did the low-fuel light is an NTC thermistor in series with a bulb. When the thermistor is submerged, it is cooled and stays high resistance - not enough current flows to light the bulb. When the thermistor is out of the fuel (low level), it drops in resistance, current goes up (and heats up the thermistor more!) until there is enough current flow to light the bulb - this increases resistance in the circuit and limits the max temp for the thermistor.... you don't want something hot enough in there to catch it on fire! That feedback/interaction between the bulb and thermistor is what gives you that slow on/off effect.
If you use an LED in place of the filament, the small current through the thermistor is still enough to turn it on - and the high resistance of the LED (compared to a cold incandescent filament) keeps the thermistor from ever changing state - you should just get a dim-ish light all the time.
The '99+ just use a comparator in the gauge cluster for when the level gets low enough (also a different sender style, etc.).
experience , gas , light , start , tank
Help! 260k miles, check engine light, multi terrain light, and slip indicator light dave_b 5th gen T4Rs 21 01-19-2021 09:20 AM
Check engine light, slip indicator light & flashing 4 Lo light croat5280 5th gen T4Rs 19 06-11-2020 05:16 PM
Please help - Engine shut off + Battery light, A/T Fluid light and OIL light Lamer 3rd gen T4Rs 11 09-03-2018 06:04 PM
Check engine light, vsc light, traction light all on after a short circuit mikeng 4th Gen T4Rs 3 01-01-2018 07:54 PM
