Originally Posted by Wolfhound_Actual
FYI, I just solved my high idle issues using a combination of this thread and this video -> Toyota Idle Air Control Valve Maintenance (Correct Idle & Cold Start Issues) | AnthonyJ350 - YouTube
Just bought a 97 Limited 4x4 and it was idling high from the start. PO mentioned that he cleaned the IAC so he thought it was a temp sensor. Bought an OBD reader, downloaded Torque Pro and verified temps were correct and ECU was going into Closed Loop. Probably not the CTS.
Turned back to the IAC. Used Tim's video to test my IAC and everything checked out electrically and otherwise. Kept reading and saw the issue plaguing Spiker and started looking up Youtube videos on how to service the IAC. I figured I needed a new one anyway so what's the harm in seeing what I could do to save this one?
In the video the guy disconnects his vacuum hose, removes the electrical coil and then hand tests how freely the valve moves. Mine was stuck solid. I stuck a rag under the IAC and started blasting TB cleaner down into the IAC port while simultaneously wiggling the valve stem back and forth. About 5 seconds it the valve broke loose and an insane amount of carbon POURED out of the bottom port of the IAC. I flushed it 3 times and it moved silky smooth.
Put everything back together and now it runs perfect. Thank you everyone for this detailed thread. Saved me a bunch of time and got my 97 running perfect again!
Good sleuthing, and I'm glad this thread helped you out, that was the intent!
Interestingly, I watched the Youtube video you linked while trying to figure out my issue. I didn't really think it applied because unlike his IAC, mine
did move, in both directions. And also passed all electrical tests.
What I didn't realize, until I fully took the IAC apart, was that while it did move, it did not move through the entire range of motion, because the carbon that I disturbed during cleaning reconstituted itself on one place, preventing the IAC from closing.
Live and learn!
