Old 04-22-2023, 02:44 PM #1
sugjavier sugjavier is offline
sugjavier will become famous soon enough
Anyone try these 2 NEW Woolwax items for rust proofing?
1. Hard-On™ Permanent hard coating
Hard-On™ Permanent hard coating-wwho
-Woolwax Hard-On is a high performance, permanent 1-time hard shell coating. NOT rubber.
-This coating is not intended to be removed (be certain that you want a permanent coating).
-Expected life expectancy is 5-10 years depending on use.
-Acts as a sound and vibration deadener.
2. Creep N' Crawl Cavity Wax
Creep N' Crawl Cavity Wax-wwcc
-Creep N' Crawl™ has no solvents or fillers. It is 100% solids which means that every raw material in the formulation is effective as a corrosion inhibitor
-There is nothing to evaporate. so if you spray on 1-2 mil thick, you will be left with exactly what you sprayed on the surface.
-One coat in the enclosed cavities and you will never need to treat that area again for 5+ years.
Looks very interesting, been using woolwax/fluid film but curious if anyone tried these out?
2001 Toyota 4Runner Limited. 231k miles.
sugjavier is offline   Reply With QuoteReply With Quote
Old 04-22-2023, 06:50 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I don't have any experience with either of these products. However. Getting hard or solid surface is a good thing.
Wool wax is the same fluid film not the products you are mentioning. The original formula is like fluid film. Similar products.
I would say if these products do what they say they will they epuld be fine..
I do know correseal with kbs or por 15 on top isn't a good plan.. as they must react and in a year it so peal off.
coating , creep , hard , permanent , years
SEASONAL RUST PROOFING using WD-40 only dogtail 3rd gen T4Rs 83 09-03-2023 08:29 PM
Greensboro Or Triad rust proofing Jay4runner7 4th Gen T4Rs 0 06-18-2020 04:37 PM
Rust Proofing the Midwest eastsideride 3rd gen T4Rs 23 10-05-2018 11:30 PM
? For those with professional rust proofing Northern 4Runner 5th gen T4Rs 18 04-23-2018 11:15 PM
Rust Proofing: Just moved to MN RPC General Discussions 11 03-02-2011 05:57 PM
