Old 04-23-2023, 02:40 PM #1
calimobber's Avatar
calimobber calimobber is offline
calimobber will become famous soon enough
calimobber's Avatar
Steering with car OFF vs ON question?
Okay so my 2002 auto 4runner has 265k miles on it and I have a question about the steering. Im trying to figure out if my steering is kinda stiff or just old suv with big tires.
Jacking the front end up and moving the wheel back and forth. For you guys does the steering get way easier to move when the truck is started?
Its not super hard to move the wheel but it does take some strength and it doesnt seem to change with car on vs off.
Im about to upgrade my steering rack cause its old and I need new tie rods anyways but just curious about how easy steering should be with 32" tires. Im temped to just get a new oem pump too just to have solid new refresh on all components.
My 2002 4runner Build : http://www.toyota-4runner.org/3rd-ge...r-project.html
calimobber is offline   Reply With QuoteReply With Quote
Old 04-23-2023, 02:47 PM #2
the_welfare_wagon's Avatar
the_welfare_wagon the_welfare_wagon is offline
Real Name: Rich
the_welfare_wagon will become famous soon enough the_welfare_wagon will become famous soon enough
Real Name: Rich
By 32s you mean 265/75?
I went to 255/85s and I did notice a difference but it’s nothing major.
By started do you mean having the truck running vs trying to turn the wheel with it off?
96 Limited: 380k+ 255/85s Geolander MTs, Ironman Nitro 2" lift, Toytec 9602HD W/FJZ80 Shocks
the_welfare_wagon is offline   Reply With QuoteReply With Quote
Old 04-23-2023, 02:59 PM #3
calimobber's Avatar
calimobber's Avatar
I have same 255/85's. its just been so long, and I cant remember what it was like before I upgraded. I dont even drive the 4runner much since its offroad/ camping rig. so makes it harder to remember.
I mean jack up the car and move the wheels back and forth. then turn the key and start the engine and do the same with the power steering pump running.
Old 04-23-2023, 03:33 PM #4
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
I have 4 toyotas, a bmw and a kia - the 4runner is by far the stiffest steering with the bmw (surprise) being next - do you think Both are 'sports machine' inclinded? LOL.
Old 04-23-2023, 04:01 PM #5
Real Name: Rich
Real Name: Rich
If both front wheels are off the ground it should be fairly easy to turn the wheel. I just purchased a rack from McGeorge Toyota myself and im hoping it tightens up the front end.
With the mileage our trucks have it would be good to get it replaced especially if you think it’s starting to have issues.
I would definitely go OEM if you haven’t bought a rack already. I scored mine for less than 600 with tax and shipping.
But to answer your question it really shouldn’t be hard to move the wheels if they are off the ground. Should turn pretty easily without much resistance
Old 04-23-2023, 04:22 PM #6
calimobber's Avatar
calimobber's Avatar
yeah id only go all OEM. I not hard just curious if someone has done the test. Other cars its a clear difference when the engines running. Becomes super easy since the power steering fluid is flowing. Like one finger can move it easily.
just be annoying if I spend $1000 on new rack and pump and it was about the same. racks not leaking or anything. looking at it when rocking the wheel back and forth shows no play in bushings either.
Old 04-23-2023, 07:08 PM #7
MaineRunna's Avatar
MaineRunna MaineRunna is offline
MaineRunna will become famous soon enough MaineRunna will become famous soon enough
MaineRunna's Avatar
You should be able to turn the wheel with one finger with it running with the tires on the ground. Not easy like an old Dodge, but do-able
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
MaineRunna is offline   Reply With QuoteReply With Quote
Old 04-25-2023, 04:59 PM #8
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
How does your stock steering rack clamp look?
Old 04-26-2023, 09:03 AM #9
nissanh nissanh is offline
Try doing a flush with a branded ATF if it hasn't been done. Clean fluid makes all the wonders!
The radius of the 4runner steering wheel is also bit small.
Looks like Texans always maintain a fleet of cars!!
1990 3L Diesel Hilux LN 106; 1973 Ford Cortina XL
1992 4AFE Toyota Sprinter AE 91 (aka Geo Prizm)
1997 5vzfe 4Runner 4x4 (aka Hilux Surf)
2000 2uzfe 100 Series Land Cruiser
2021 Tacoma TRD Off-Road 4x4 6-speed
Old 04-27-2023, 08:45 PM #10
calimobber's Avatar
calimobber's Avatar
Its good. I swapped the bushing out at some poin. maybe 5 years ago.
Yeah ive done a full flush and cleaned the screen. its prob fine just normal old age and big tires.
Ill prob replace at somepoint soon just to get new tie rods but thanks for the info.
car , move , question , steering , wheel
Loose steering and wobbly steering wheel even after steering rack bushing replacement psyduck 3rd gen T4Rs 18 07-17-2022 07:17 PM
'85 steering box question 88rnr Classic T4Rs 1 05-20-2018 09:17 PM
2003 V8 90k Maint. Question + Steering Question zerowkul98 Maintenance/Detailing 1 10-21-2010 07:35 AM
Power steering/steering rack question (need help fast) alex bland 3rd gen T4Rs 9 01-09-2010 07:37 PM
03 steering question, shootmymime 4th Gen T4Rs 2 08-17-2008 09:32 PM
