Old 04-25-2023, 04:47 PM #1
BretMann BretMann is offline
BretMann is on a distinguished road
Workaround for Knock Sensor & Fuel Filter replacement access
Having recently changed the fuel filter, I already removed and replaced the whole intake assembly as per the Hanes manual. I didn't see how to access it from below by removing the starter motor or from the side by taking off the wheel well. I didn't want to do it again so soon to now diagnose the knock sensor.
The knock sensor in my 3RZ-FE motor is right above the the stock fuel filter on the driver's side of the motor. To get to both the whole intake assembly needs to come out as per the Hanes manual.
I discovered that by swinging the power steering pump over to the driver's side some, still connected but held up with some zip ties, I could reach the knock sensor ok but it's all by feel. Getting a hand or wrench on it was not a problem.
It might be possible to change the fuel filter too if the power steering bracket is also removed because that would make even more access room. Moving the power steering pump over and back on again is easy.
I'm planning to add a pre-filter into the fuel line under the truck where that will become the new normal fuel filter location. Other 3 gen 4runner models have it there but not mine. Toyota engineers must have been hung over when they made that decision.
Hope this helps someone.
Bret
1999 4Runner(3rd Gen) Base, Engine: 2.7L (3RZ-FE), Trans: 5sp manual (W59)
Miles as of 10-2022: 107k
VIN: JT3GM84R2X0047863
BretMann is offline   Reply With QuoteReply With Quote
Old 09-27-2023, 11:33 AM #2
jruffinb jruffinb is offline
jruffinb is on a distinguished road
Transmission Stiffner Bracket Driver's side
There is a transmission stiffner bracket on each side of the bellhousing that connects the block to the transmission. I cant find this part and I am worried that the bellhousing will crack. There is no Part Number.
I can fabricate one but I need to get the dimensions to copy it. SO infuriating.
I have a 2.7L 1996 Base with a 5speed. Does anyone have any suggestions?
jruffinb is offline   Reply With QuoteReply With Quote
filter , fuel , knock , motor , sensor
Knock Sensor and Knock Sensor Wiring Harness Replacement mtbtim 3rd gen T4Rs 10 05-16-2022 02:52 PM
Air Fuel Ratio Sensor and o2 Sensor Replacement - P0136 and P2195 Smurray 4th Gen T4Rs 5 02-25-2019 08:21 PM
Fuel Injector + Knock Sensor CEL codes -- separate issues or related? marcus clarkus 3rd gen T4Rs 3 03-04-2018 08:15 PM
Knock Sensor Fault/ HG replacement? Buck Bridges Classic T4Rs 11 05-20-2014 03:23 PM
knock sensor replacement 904runner80917 Classic T4Rs 6 04-13-2011 10:08 AM
