Old 04-25-2023, 05:18 PM #1
the_welfare_wagon's Avatar
the_welfare_wagon the_welfare_wagon is offline
Real Name: Rich
the_welfare_wagon will become famous soon enough the_welfare_wagon will become famous soon enough
Real Name: Rich
rear upper control arm difference questions
So my rear upper control arms bushings are shot and im looking into replacing them. Before anyone says it, no im not buying OEM for this and im not going to press out bushings for it.
Ive come across two options on rockauto, One is listed as RWD and the other does not specify however it is 20 dollars more expensive. Are there any actual differences between these two? The pictures provided show no difference that I can visually see.
Can I just use the RWD one? It looks no different than whats currently on the truck and I cant imagine the RWD version having different links, maybe they are not as thick?
Thoughts?
Links to them are below, they are the first two options suspensia and mevotech
1996 TOYOTA 4RUNNER 3.4L V6 Control Arm | RockAuto
96 Limited: 380k+ 255/85s Geolander MTs, Ironman Nitro 2" lift, Toytec 9602HD W/FJZ80 Shocks
the_welfare_wagon is offline   Reply With QuoteReply With Quote
Old 04-25-2023, 05:22 PM #2
spartacus's Avatar
spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of
spartacus's Avatar
Thoughts?
The 2wd are shorter due to the required pinion angle. Courtesy of @phattyduck
Old 04-25-2023, 07:40 PM #3
Zhehan Zhehan is offline
Zhehan will become famous soon enough Zhehan will become famous soon enough
I bought a pair of these recently. I'm impressed with their build quality and the improvement they made to the handling of the truck.
More Information for MEVOTECH CMS861168
Comparison of the stock arms to the Mevotech Supreme arms:
rear upper control arm difference questions-20230330_175359-jpg
2000 4Runner SR5 Manual Trans Federal Emissions - Eibach Pro-Truck coilovers, LC 7.5/Tokico Black, JBA UCA, SPC 25945 RLLs, Mevotech Supreme RULs, TrakMotive Xtended Travel CV Axles TO-8043ET, South Bend Rally Clutch, ES & Whiteline Bushings, MagnaFlow Cat-Back, Deck-Plate Mod, 4.56 Yukon Gears, Yukon Grizzly Rear Locker, Bushwacker Flares, 16x8 Wheels w/ 285/75 General Grabber AT2, 229K+ Miles
Zhehan is offline   Reply With QuoteReply With Quote
Old 04-26-2023, 01:19 PM #4
Real Name: Rich
Real Name: Rich
Thank you!
Old 05-21-2024, 10:58 PM #5
Cocoyraisa Cocoyraisa is offline
Cocoyraisa is on a distinguished road
Is your truck a 4wd or 2wd. I'm having trouble deciding which rear upper control arm I need as the ones in rock auto are not labeled too well
Cocoyraisa is offline   Reply With QuoteReply With Quote
Old 05-22-2024, 02:39 PM #6
Most posters on here have a 4WD.
If the arms aren't rusted (depends on where you live...), you can just put in new bushings to the stock arms too.
ENERGY SUSPENSION 83133G - available on RockAuto too.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 05-24-2024, 03:17 PM #7
My 4Runner is a 4WD version
Old 05-25-2024, 02:18 AM #8
gh25_'s Avatar
gh25_ gh25_ is offline
Real Name: Garrett H.
gh25_ will become famous soon enough
gh25_'s Avatar
Interesting figuring this out now! My 1998 is a 2WD v6 and I didn't want to bother pressing out the old bushings on my old arms so i just bought a set of the Jason Opt Offroad jhonny joint rear arms. When I was putting the links in I was trying to figure out why I couldn't get the upper links to match stock length like the lowers were able to. I couldn't adjust the uppers any shorter to match the OEM length. I thought something was off but put them on anyways. This is a funny way to figure out that the 2WD upper links are shorter. I would have never knew. Phatty duck has always got that secret info.
gh25_ is offline   Reply With QuoteReply With Quote
links , options , rear , rwd , upper
Upper rear control arms all the same? St Runner 3rd gen T4Rs 2 01-11-2021 10:25 AM
Upper & lower rear control arm Poorboy64 3rd gen T4Rs 7 12-28-2020 10:52 AM
rear upper control arm bushings ? 3bears 3rd gen T4Rs 6 08-02-2020 08:21 PM
What's the difference between upper control arms from multiple models?? eurasiaoverland 3rd gen T4Rs 2 05-27-2016 03:56 PM
rear and upper adjustable rear control arm length ryanberls 4th Gen T4Rs 4 02-17-2016 10:50 AM
