Old 04-26-2023, 01:13 PM #1
the_welfare_wagon's Avatar
the_welfare_wagon the_welfare_wagon is offline
Real Name: Rich
the_welfare_wagon will become famous soon enough the_welfare_wagon will become famous soon enough
Real Name: Rich
Cam bolts
So I’m doing my lower control arms/steering rack next weekend and am likely going to have to cut the old cam bolts out.
Does this kit from rock auto have everything I need for the cam bolts? Don’t want to get into this job and find out I’m missing something.
Obviously I will need two of these kits but do these include everything I need assuming everything on the truck is NOT reusable?
96 Limited: 380k+ 255/85s Geolander MTs, Ironman Nitro 2" lift, Toytec 9602HD W/FJZ80 Shocks
the_welfare_wagon is offline   Reply With QuoteReply With Quote
Old 04-26-2023, 01:37 PM #2
Zhehan Zhehan is offline
Zhehan will become famous soon enough Zhehan will become famous soon enough
It does have all the parts for one side. I'd go with the Mevotech Supreme kit if I was gonna go aftermarket before I'd buy something that cheap.
More Information for MEVOTECH MS86042
2000 4Runner SR5 Manual Trans Federal Emissions - Eibach Pro-Truck coilovers, LC 7.5/Tokico Black, JBA UCA, SPC 25945 RLLs, Mevotech Supreme RULs, TrakMotive Xtended Travel CV Axles TO-8043ET, South Bend Rally Clutch, ES & Whiteline Bushings, MagnaFlow Cat-Back, Deck-Plate Mod, 4.56 Yukon Gears, Yukon Grizzly Rear Locker, Bushwacker Flares, 16x8 Wheels w/ 285/75 General Grabber AT2, 229K+ Miles
Zhehan is offline   Reply With QuoteReply With Quote
Old 04-26-2023, 02:41 PM #3
Iron duke's Avatar
Iron duke Iron duke is offline
Iron duke has a spectacular aura about Iron duke has a spectacular aura about
Iron duke's Avatar
If you have adjustable UCA's I'd get the 333fab cam eliminators
Iron duke is offline   Reply With QuoteReply With Quote
Old 04-26-2023, 04:00 PM #4
Romeo1's Avatar
Romeo1 Romeo1 is offline
Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice
Romeo1's Avatar
Gun drilled LCA cam bolts.... now that's cool.
It's a good thing it's greaseable though..... That thing probably welds his self to everything in five minutes from the Chineseium plating.Cam bolts
That does seem very inexpensive for what you get. That's one area I don't like to skimp out on, but your mileage may vary. I would put a very light coat of anti seize at least. Them damn things for anyone outside of the southwest desert always seem to weld them selves into a petrified ball of crap with enough time.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
Romeo1 is offline   Reply With QuoteReply With Quote
Old 04-26-2023, 05:40 PM #5
Real Name: Rich
Real Name: Rich
I was considering them but up front I’m stock. No lift or anything just bigger tires
Old 04-26-2023, 05:41 PM #6
Real Name: Rich
Real Name: Rich
Oh yeah at this point I haven’t even given any thought to them just coming loose nicely. After 26 years I’m sure they are basically one piece now.
Old 04-26-2023, 05:57 PM #7
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
I wouldn't waste my money on them again, the D holes in cam washers strip out very easy.
Old 04-26-2023, 08:29 PM #8
Rushthezeppelin Rushthezeppelin is offline
Rushthezeppelin has a spectacular aura about Rushthezeppelin has a spectacular aura about Rushthezeppelin has a spectacular aura about
This, those look suspiciously like rebranded Moog cams which are know for stripping out the D holes. Sucks because the idea of greasable cam bolts is great in theory. I would just go OEM and slather them in marine grease. That seems to be the longest lasting solution to this problem. Might as well take the opportunity to replace your bushings while you are in there as well. There's a chance you might not even be able to get a sawzall blade on the outside of the bushings anyway and would have to cut at least one side into the bushing which is what happened to me. I went and grabbed some LCAs from a junkyard recently and put whiteline polys in them and swapped those with my arms with worn out bushings one of which also had frozen cams. I think the whiteline also solves the issue of frozen cams too since even if the cam sleeves freeze to the bushing sleeve the cams will then just turn the bushings sleeves inside of the bushing instead of binding the bushing like with the OEM design where the rubber is attached to the inner sleeve. I even grabbed some OEM cams that were in good condition when I was grabbing the arms from the junkyard and cleaned them up with a wire wheel, they came out looking almost new and of course were way way cheaper than buying ones from the dealership (in fact I think the yard gave them to me for free with the arms).
'98 SR5 5 Speed
Rushthezeppelin is offline   Reply With QuoteReply With Quote
Old 04-26-2023, 11:14 PM #9
Real Name: Mark
Real Name: Mark
Marine grease is good will wash out before anti-seize will.
Old 04-27-2023, 12:07 AM #10
? Your statement is confusing. I went with marine grease after several people talking about how it washes out slower than antisieze.
'98 SR5 5 Speed
bolts , cam , include , i’m , kits
TRD Pro skid plate bolts - for those with a spacer on the skid because of lift..bolts chrissurfr 5th gen T4Rs 1 11-23-2021 04:39 PM
Flywheel bolts vs. Flexplate bolts??? Fadiddy 3rd gen T4Rs 13 09-07-2019 08:24 PM
Sheared bolts and seized bolts. Need help. mavrick1903 4th Gen T4Rs 8 07-18-2017 01:33 PM
SPC vs OEM Cam Bolts nicheel8 4th Gen T4Rs 6 01-08-2017 07:27 PM
U-bolts MT4runner Classic T4Rs 2 02-22-2008 12:28 AM
