05-04-2023, 07:49 PM
Savage rock rails... still around?
hey ALL,
Does anyone know if Savage(rails bumpers) are still around? either their site changed or they did. I have some questions about what kind of steel they use in their Rock Rails.
THANKS
Magnaflow, Rigid D Series 4" 50231/Rigid E Series 20" 12231 LED Bar ,K&N FIPK,3"Toytec ultimate, OEM 231MM brake upgrade, LED Interior upgrade,Bushwackers,Savage Rock Rails,Shock works front bumper,PERKINS NON PERFORMANCE REAR BUMPER 33'Duratracs,Kenwood DNX891HD JL Audio C5's
Currently 194K
Cheers
05-04-2023, 08:36 PM
Real Name: Evan
Real Name: Evan
Originally Posted by giguchan
hey ALL,
THANKS
They closed permanently a couple years ago.
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
05-04-2023, 08:38 PM
Roy Lewis retired.
05-04-2023, 11:32 PM
Thanks for the replies.
I'll have to search out my invoice. My Rails dues to improper prepping are rusting..i had a friend ask me what gauge steel was used. So that's the question.
Thanks again.
Currently 194K
Cheers
05-06-2023, 12:21 PM
Another issue.... prob not due to the Bars... but just prep
Currently 194K
Cheers
05-06-2023, 12:28 PM
you get the idea.... Remove from the vehicle and then fix? or fix while on the truck?
Currently 194K
Cheers
05-06-2023, 03:37 PM
oof! That looks pretty rotten...
Most tubing is typically .120" wall DOM or ERW
You may be able to replace on the vehicle, but weld access can be tough,
and the notched tubing might fight you a bit since you usually need to rock it into place.
Build Etc...
If it ain't broke, fix it 'til it is.
05-07-2023, 12:57 AM
hEY!!!!
That looks like my Ex's Momma! How'd she get in there!!??
Nice one!!
Currently 194K
Cheers
05-07-2023, 01:08 AM
Yikes! That road salt is killer! Try Marlin Crawler or All Pro Off Road for good sliders.
05-07-2023, 02:40 AM
Thanks for the heads up i'll have a look at their site.
Currently 194K
Cheers
