Old 05-08-2023, 08:05 PM #16
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Originally Posted by Nathan97Limmited View Post
Alright today I re checked all the senor's and the MAF sensor is not getting any ohms! would this really cause no engine start ??
Normally I'd say go get a spare but you have a 97 with the larger turbine-style MAF and they cost $100's the last time I looked. Even used ones run about $50+. The testing procedure for the MAF in the factory service manual is sort of complicated so a single reading may not give a true picture of what's going on. However, one of the wires on the connector should be providing voltage with key on (I think it's the bronze colored pin) with the MAF disconnected.
Any voltage or resistance that is out of spec WILL throw a code though so if no codes, MAF is fine.
326WHP 347TQ
Old 05-08-2023, 09:35 PM #17
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Would it make sense that a MAF would just fail? I mean it was working before the engine change correct?
Old 05-09-2023, 03:20 AM #18
JBurt's Avatar
JBurt JBurt is offline
Real Name: Jeff
JBurt has a spectacular aura about JBurt has a spectacular aura about
JBurt's Avatar
Real Name: Jeff
That seems like a good lead, but I don't know.
All I have to contribute at this point is a dumb question: Was the new engine running before you swapped it in?
97 SR5 4runner: 2" OME Lift, rear E-Locker, 231mm Tundra Brakes, 203K, B&M 70264 Tranny Cooler, Duratracs
Build
JBurt is offline   Reply With QuoteReply With Quote
Old 05-09-2023, 10:29 PM #19
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
thanks for the help. I was thinking this too I put on a new Crank shaft pully bolt but the new timing belt was already one so i left the gear for that. My question is could they but the timing gear for the belt on wrong? I thought that gear had a key as well as the gear that sends a signal to the crank shaft sensor. But I understand what you mean it could be damaged sending a wrong signal. I also wonder if the cam shafts could be off by 180 degrees is that possible?
No, it's not. Because of the waste-spark system, off by 180 degrees is actually in time. The sensors drive the ignition timing, so the spark will occur when it is supposed to. It's not like the old distributor days when the ignition timing was done mechanically; then you could get 180 degrees off on ignition timing.
The gear has a key, but it can shear if the HB bolt torque is too low, and it needs major torque. Shops fail to meet the torque spec every now and then, if you follow the board for as long as I have. The same key does engage the HB, but only by about a quarter inch. So it is possible to install the HB without correctly engaging the nub, and then the whopping torque will just mash the end of the key. In either case, the HB time mark will not line up with the crank and give a false indication of good valve timing.
Did you have the HB off when you installed the new crank bolt? Could you confirm the key was intact and that the HB engaged the little nub end of the key? If so, then you are good because the key can't shear if the engine never ran. Still, one broken tooth on that sprocket can mess up the ignition timing.
This is not something that happens often, but you are running out of things to check.
EDIT: Sorry, I just saw you ruled this all out. As I recall, if you forget to plug in the MAF it won't start so no ohms can't be good.
My Backyard Frame Swap
Old 06-02-2023, 04:13 PM #20
Nathan97Limmited Nathan97Limmited is offline
Nathan97Limmited is on a distinguished road
Originally Posted by 19963.4lsr5 View Post
My 97 will not start if the MAF is unplugged.
You never mentioned if you verified the cam timing.
Bingo! It was the timing on the Cams they were very very off most valves on both sides were opening at the same time. Got them back to the correct position and it started right up. Cant believe who ever had this engine before me would take something like that apart and not have the know how to put it back together properly. SO I get the cams timing correctly I left the intake Cams in. As they were already timed correctly with the timing belt to the crank. and took the Exhaust cams out on each side. I get it all back together and it starts right up. Almost immediately it starts to over heat -_- The water pump is new the thermostat is new the radiator is new the timing belt is put on correctly to spin the pump. I got all the air out of the system but still seems to overheat. Long story short its the head gasket -_- haven't got it apart yet to confirm but the air keeps coming out (its coming from some where) and you can hear the top end boiling over. This whole project has been a disaster. I spent 3 days changing the engine and a month trying to find issues and fix issues with it. But I'll know this engine inside and out by the end of all this. It has new head gasket on it you can tell from the outside SO I think the heads are just very warped. I'll update with photos when I get to the head gasket. Thanks for all the help everyone!
Oh and the MAF was actually fine I had a a general Toyota manual for all years and I didn't know this at the time but the pin out for the MAF changes over the years of the 3gen 4runner.
Nathan97Limmited is offline   Reply With QuoteReply With Quote
Old 06-02-2023, 04:26 PM #21
HiLife HiLife is offline
So...the person who you got the engine from, not only out timed the cams, but also had a potential head gasket issue and didn't tell you about it until it ran? Wow
Glad you were able to figure it out and got the 4r running.
Old 06-02-2023, 04:37 PM #22
diverscale's Avatar
diverscale diverscale is online now
diverscale will become famous soon enough
diverscale's Avatar
Man good luck with that, it must feel like crap to be this deep into the rabbit hole because of the bad work of someone else. If at least he told you, you could have done the head in-situation before putting the engine in.
good luck, keep us updated.
1998 4runner SR5
diverscale is online now   Reply With QuoteReply With Quote
Old 06-02-2023, 08:59 PM #23
Real Name: Jerod
Real Name: Jerod
Dang, that's really shady. I realize this is of no help to you now but when I was shopping for an engine I had them do a compression test right in front of me. A tip for anyone in the future reading this thread.
326WHP 347TQ
Old 06-02-2023, 09:16 PM #24
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
So not only did they super jack the valve timing. The engine had blown head gaskets. Man no wonder you can not get this engine to run. :-(
Glad you found out was was the issue. Timing. I am hoping now, you get the rig all patch up and rolling down the road..
checked , engine , fuel , running , start
When trying to start the starter spins but engine won't start this is why. Ralph Blake 4th Gen T4Rs 7 09-17-2022 03:34 AM
Engine bog, then stalling at stop signs, now engine won't start Smiley52 3rd gen T4Rs 32 05-05-2017 05:15 PM
How do I change the start up display pic? SavageRunner 5th gen T4Rs 2 07-26-2014 09:41 PM
Fluttering engine start when engine is cool. trail_runner 3rd gen T4Rs 1 07-17-2013 09:24 AM
4runner' 99 won't start for 1st,2nd,3rd but eventually will start the engine tm1579 3rd gen T4Rs 5 04-16-2013 01:14 PM
