Finally a replacement LCA from TOTAL CHAOS that features a urethane pivot bushing and secondary tab for dual shock capability. Want to retain your sway bar? No problem! The secondary shock tab allows you to reinstall your sway bar for better cornering stability when not installing dual 2.5" shocks.
Toyota 4Runner 1996-2002 3RD GEN 4RUNNER EXPEDITION SERIES STOCK LENGTH LOWER CONTROL ARMS | TOTAL CHAOS FABRICATION
Maximize the upgrade by adding the TOTAL CHAOS lower uniball conversion. Will work with stock ball joints.
Toyota 4Runner 1996-2002 3RD GEN 4RUNNER LOWER UNIBALL CONVERSION - OE TIE ROD | TOTAL CHAOS FABRICATION
Stock length heim tie-rod upgrade COMING SOON
https://www.chaosfab.com/images/prod...shocks-web.jpg
