Old 07-17-2023, 08:09 PM #16
BetterontheMtn BetterontheMtn is offline
BetterontheMtn is on a distinguished road
THREAD RESURRECTION!
After shaking the hell out of the truck, jiggling everthing underneath I could, Smacking stuff, prying on stuff....I'd had enough.
I bought a set of Chassis ears on Amazon.
Finally got time to mess about with them tonight.
Round 1
6 leads placed along both sides of the truck.
Drivers side: brake hose bracket, transmission crossmember and finally back on a rear body mount.
Passenger side: Brake hose bracket, sway bar to frame mount bracket, upper trailing arm forward mount on frame
Immediately upon hearing the noise the front passenger lead lit up.
Round 2
Front Skid plate,
Front shock tower,
Sway bar mount
Middle body mount.
BINGO.....Sway bar mount and nothing else.
Round 3, One lead on the front of the sway bar mount
One lead on the rear portion of sway bar mount.
One lead zip tied to the sway bar itself between the frame mounts
Again, only the sway bar mount lights up when I head the noise.
So....when I next have time I'll replace both the mount bushings, and cross my
fingers.
btw...chassis ears are so cool.
BetterontheMtn is offline   Reply With QuoteReply With Quote
Old 07-17-2023, 09:45 PM #17
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Round 1
Round 2
Front Skid plate,
Front shock tower,
Sway bar mount
Middle body mount.
fingers.
I have never heard of those before. I'll have to check that out!
326WHP 347TQ
Old 07-18-2023, 10:47 PM #18
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
Never heard of those either, but it's usually the sway bar end links that be clunkin.
258K - Y2K/E - Clock still works
Old 07-18-2023, 11:21 PM #19
diverscale's Avatar
diverscale diverscale is offline
diverscale will become famous soon enough
diverscale's Avatar
When I got the truck back in 2015 I had a clunk similar to yours felt in the steering but it was weird.
It drove me totally ape shit crazy. I replaced pretty much the entire front end chasing this clunk, every ball joints, every bushings, LCA, the entire steering rack and also its bushings you name it.
Finally it was my body mount bushing and its bolt, the one just beside your left feet while driving. Tightening it fixed it to a small extent, but the bolt was also moving into the rusty guide hole, so welded it, rust proofed it, and it's holding right there since then and no more clunking.
1998 4runner SR5
diverscale is offline   Reply With QuoteReply With Quote
Old 07-25-2023, 10:56 AM #20
These are the Chassis Ears I got, pretty slick gizmo.
I was warned by a tech I work with to zip tie the leads in place so they don't vibrate loose.
Amazon.com
Old 07-25-2023, 05:42 PM #21
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Never heard of these chassis ears before, thanks for the tip, gonna look more into them later. I could really use these trying to track down this damn clicking noise
Old 07-31-2023, 03:59 PM #22
ITS GONE!
After the chassis ears lead me to the passenger front sway bar mount, I ordered a new set and last Saturday got the time to install them.
The culprit has been identified and eliminated!
I had to drill out the stud as it just broke free and began to spin.
Thank you all for your help and support.
I'm insane a little less today.
Right turn clunk help, please, for my sanity....-damnedthing-jpg
bar , center , clunk , truck , wheel
Clunk noise when straightening after tight right hand turn... ideas? DirtDrift 3rd gen T4Rs 2 03-21-2020 09:45 AM
Steering clunk... clunk over hard bumps kruegs 3rd gen T4Rs 30 12-12-2017 03:50 PM
Clunk noise on full lock right turn MT4Runner2000 Engines / Suspension / Wheels / Tires / Audio / Accessories 1 10-06-2014 02:57 PM
Clunk in full turn reverse jamesq 5th gen T4Rs 17 04-05-2014 03:05 PM
Loud "Clunk" with slight left hand turn? STRRAYNGE 3rd gen T4Rs 38 04-24-2012 01:48 PM
