Old 05-18-2023, 09:22 AM #1
BetterontheMtn BetterontheMtn is offline
BetterontheMtn is on a distinguished road
Right turn clunk help, please, for my sanity....
Help. Please.
97 Limited 4WD
Within the last few years the following has been replaced:
Both CV axles
Passenger Inner Tie rod
Tundra Brake upgrade (the smaller of the two tundra calipers)
Rotors (twice, long story..)
Lower Ball Joints
Sway Bar end links
Shocks all around
Rear springs
Replaced a little further back in time
Steering Rack mount bushings
Sway bar mount bushings
Now...the fun stuff.
When turning to the right, past center, and anything more than a few degrees there is an audible clunk. It can be felt in the steering wheel.
It will clunk once while turning right, then nothing as the wheel returns to center. It does not need to go past center to repeat the sound.
Had the truck in the air at my work the other day, pry bar on all sorts of stuff but no movement. LBJ's look good. The truck drives like its on rails. No handling concerns to speak of.
This noise has given me gray hairs.
I've seen the threads about the Rack tensioning bushing (but haven't seen it described as a one way sound)
I also will say that it doesn't seem to happen at the same spot when turning the wheel. For example, sometimes just a little steering right input and clunk, others a tighter turn before the clunk.
I've attached a map of my commute and highlighted the turns that typically illicit a clunk. Heading north (up) is an elevation drop of about 1400 feet total in the stretch shown. So the truck is front heavy and sometimes under breaking when it clunks
The reverse is also true and when heading back up the mountain it will clunk with no brakes and neutral to rear heavy.
Seriously...I'm losing my mind here.
Help,
Thanks in advance.
Right turn clunk help, please, for my sanity....-clunk-png
BetterontheMtn is offline   Reply With QuoteReply With Quote
Old 05-18-2023, 12:02 PM #2
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
I know that the Upper Ball Joints can clunk over speed bumps and things like that but this seems a bit different. If you jack the front end into the air (with support stands) and turn the wheel left and right does it clunk? If yes, there's something gone wrong with the rack and pinion. If not, it could be something else like CV axles.
326WHP 347TQ
Old 05-18-2023, 02:47 PM #3
the_welfare_wagon's Avatar
the_welfare_wagon the_welfare_wagon is offline
Real Name: Rich
the_welfare_wagon will become famous soon enough the_welfare_wagon will become famous soon enough
Real Name: Rich
Dumb question but does this clunk only occur when the truck is moving?
96 Limited: 380k+ 255/85s Geolander MTs, Ironman Nitro 2" lift, Toytec 9602HD W/FJZ80 Shocks
the_welfare_wagon is offline   Reply With QuoteReply With Quote
Old 05-18-2023, 04:31 PM #4
Ph03n1x24's Avatar
Ph03n1x24 Ph03n1x24 is offline
Real Name: Mark
Ph03n1x24 is on a distinguished road
Ph03n1x24's Avatar
Real Name: Mark
Sounds like either a sway bar or tie rod problem. Especially if you have handling issues.
Might want to also check the control arms, struts, and rack.
Here's a helpful video: Can't Locate Clunking/Banging Sound on Your Car or Truck? Quickly Identify Often Overlooked Parts - YouTube
2005 Toyota 4Runner Sport Edition 4.0L 6cyl 5A | 5th Gen TRD wheels w Dunlop 265/70R17 113 S Tires | CKAuto 2" Hub Centric Wheel Spacers | 3" Lift + 1" leveling kit | Pro FOX Coilover Shock Suspension Kit | Deleted Hydraulics | Retrofit LED / USB 3.0 | PC38 Pedal Commander | Alpine iLX-w650 w KTA450 | Kicker KS Series 6"x9" 3-way - CS Series 3/4" dome tweeters - KS Series 6-1/2" 2-way | Hifonics BXX1200.1D 1200W RMS 1 Ohm amp | Dual JL 10w6v2's |Q box 50hz
2011 Toyota 4Runner SR5 - Soundproofing | HU & Speaker Upgrades
Ph03n1x24 is offline   Reply With QuoteReply With Quote
Old 05-18-2023, 06:50 PM #5
Storm01's Avatar
Storm01 Storm01 is offline
Storm01 is on a distinguished road
Storm01's Avatar
Call me crazy but are your body mount bolts loose/bushings bad? I had something very similar and it turned out to be loose bolts connecting the mount to the frame.
I would also look at your steering stops perhaps? Mine were really popping for awhile, greased them up and no noise since.
2001 T4R SR5 4WD: Lifted and Armored- Eibach
Coils w/5100s & 891s. 265/75R16 KO2s
Storm01 is offline   Reply With QuoteReply With Quote
Old 05-18-2023, 07:17 PM #6
Dezert4Runner's Avatar
Dezert4Runner Dezert4Runner is offline
Real Name: Evan
Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about
Real Name: Evan
You said you had the truck in the air and used the pry bar, but I would manually test tie rods by grabbing 9 o’clock and 3 o’clock on the wheel for both sides of the vehicle just to make sure they’re not the culprit.
After that, my money is on LCA bushings. I know when I’ve had alignment done at Firestone and they don’t tighten everything up well, my truck has made the clunk sound. It’s likely the bushings are the actual issue if there wasn’t any work done on the vehicle right before it started making noise.
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
Dezert4Runner is offline   Reply With QuoteReply With Quote
Old 05-18-2023, 09:24 PM #7
Amazing input from all. I'll try to answer all questions here.
In the air, no clunk. I tried and tried and tried.
Sitting still (on concrete with carpet squares under the wheels) no clunk
Sitting still on concrete/asphalt no clunk
Handles like a dream. (Better than my 02 Tundra actually)
I've had the tie rods off the spindles on both sides. Tight on both sides for all 4 joints.
Update: Today at work in the shop on the concrete floor I shook the ever loving hell out of the truck(side to side rocking) and FINALLY duplicated the sound. But time was a factor and we didnt have time to diag further.
I'll re read this tomorrow and make a game plan to address things I haven't yet.
How does one inspect the body mounts? I know the truck was in a passenger right front collision before we purchased.
Old 05-18-2023, 09:25 PM #8
No clunk in the air and not really affected by speed bumps/potholes
Old 05-18-2023, 09:26 PM #9
No dumb questions! But yes only when moving (until I hop up and down and get the truck absolutely rocking side to side.)
Old 05-18-2023, 09:27 PM #10
So, I'll investigate this, but it doesn't happen at full lock, or even close to full lock. Isn't that where the stops come in?
Old 05-18-2023, 09:29 PM #11
I love hate this reply. Will investigate. I've done two sets of LCAs on my tundra (much more corrosion prone somehow?) Its not a job I love.
Old 05-18-2023, 10:52 PM #12
Real Name: Jerod
Real Name: Jerod
Ok, so you got the clunk with no turning of the wheel. I think that effectively rules out anything tie rod or steering related. I would look then to frame items or body mounts like others suggested. A loose body mount could make sense. The sway bars see serious tension on even the slightest turns (left AND right) so I don't think it is the sway bars.
This might seem really old school but make yourself a list and write down everything suggested here. Then cross off everything that you know 100% that it is NOT. Your list will get smaller and smaller until you find the culprit. We can keep spitting out ideas if you reach the end of your list ha
326WHP 347TQ
Old 05-18-2023, 11:08 PM #13
Real Name: Rich
Real Name: Rich
On the LCA bushings topic. I sort of had a similar situation with this.
My bushings were so shot that when I hit the brakes the arms made a very audible groan from shifting due to the bushings being shot. I never had a clunk but I would say that’s it’s entirely possible like others have mentioned.
Another thing to check is where the steering wheel goes into the rack on the rag joint (I think it’s called that lol) or possibly one of the inners has play?
I know it’s a pain to do on this website but if you could upload a video of the noise it would certainly help
Since you can sort of replicate the noise without moving I’d say shake the hell out of the truck again and have someone underneath to help pinpoint exactly where it’s coming from
Old 05-19-2023, 05:10 PM #14
2old2soon 2old2soon is offline
2old2soon is on a distinguished road
Regarding the OP's "clunk" sound, his issue reminded me of a post I saw in one of the Facebook 3rd gen Groups. Here's the link, which also contains quite a few comments which might be helpful.
页面未找到 | Facebook
Here's the quote that caught my eye: "If you hear a slight clunk when rotating steering wheel at stop this can be culprit."
The comments also include a link to one of Tim's videos which addresses how to replace the steering rack guide, if that turns out to be the problem.
2old2soon is offline   Reply With QuoteReply With Quote
Old 05-19-2023, 10:46 PM #15
jsnppp jsnppp is offline
jsnppp will become famous soon enough
I recently tracked down a funky creak when turning on my 3rd gen. I did two things at once and so I can't be sure which one.
1. I torqued the lower control arm bolts to 130 ft lbs. Manual says 100 and I feel mine were less than that. Folks on this board said they loosen over time.
2. I tightened the front sway bar brackets. The passenger side was "slightly" loose (I think this was the culprit).
Anyway, it doesn't feel the same as yours but I wanted to toss out there what I did.
I agree, get 2 friends to shake the F out of the truck while you crawl under it and find it. 3 friends to shake it is even better.
Good luck! You will find it I am sure.
Jason
~ Jason
2002 4Runner 4wd SR5 Sport Edition
+ many other cars
jsnppp is offline   Reply With QuoteReply With Quote
bar , center , clunk , truck , wheel
Clunk noise when straightening after tight right hand turn... ideas? DirtDrift 3rd gen T4Rs 2 03-21-2020 09:45 AM
Steering clunk... clunk over hard bumps kruegs 3rd gen T4Rs 30 12-12-2017 03:50 PM
Clunk noise on full lock right turn MT4Runner2000 Engines / Suspension / Wheels / Tires / Audio / Accessories 1 10-06-2014 02:57 PM
Clunk in full turn reverse jamesq 5th gen T4Rs 17 04-05-2014 03:05 PM
Loud "Clunk" with slight left hand turn? STRRAYNGE 3rd gen T4Rs 38 04-24-2012 01:48 PM
