Old 05-20-2023, 02:04 AM #1
ir0nma1den ir0nma1den is offline
ir0nma1den is on a distinguished road
Weird battery issue
Last week I noticed that I would have to hold the key in the start position for longer than usual to get the engine going. I left town for a week and came back to my 4runner unable to turn over. Instead, I get a rapid clicking sound which I think is the starter, but no turn over. I replaced the contacts and solenoid in my starter (8/17, 50k miles ago). My battery is definitely old (5/18) but I have a suspicion that it has something to do with the fuse. When I have the key turned to the on position, my dash, radio, and antenna start to work but they will all suddenly shut off after about 2 seconds and try to turn on again, repeating the cycle. This makes me think it’s a relay or fuse. The battery also seems to drain quickly as I got it jumped which didn’t help at all.
ir0nma1den is offline   Reply With QuoteReply With Quote
Old 05-20-2023, 08:07 AM #2
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
I would start by checking the overnight sitting voltage of the battery, s/b at least 12.6 or more to effectively spin the engine over fast.
Also make sure the battery cables are tight. Let us know what you found.
2001 Limited 4WD - 340+K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL - StopTech ANGLED rotors - In series 699 trans cooler, New Yota1 transmission, All new OEM suspension front to rear.
Old 05-20-2023, 10:18 AM #3
the_welfare_wagon's Avatar
the_welfare_wagon the_welfare_wagon is offline
Real Name: Rich
the_welfare_wagon will become famous soon enough the_welfare_wagon will become famous soon enough
Real Name: Rich
I would just bite the bullet and get a 50 dollar battery from Walmart. Eliminate the most obvious thing first before trying to delve into anything wiring/electrical related
96 Limited: 380k+ 255/85s Geolander MTs, 99 Talls W/5100s + OME 890s W/FJZ80 Shocks
the_welfare_wagon is offline   Reply With QuoteReply With Quote
Old 05-20-2023, 10:38 AM #4
Ripper238's Avatar
Ripper238's Avatar
Totally agree. Sounds like a well worn Battery or poor connections.
Old 05-20-2023, 02:03 PM #5
Per the recommendations in this thread, I picked up a 24F interstate battery from Costco. So far, so good, the engine spun right up. Is there anything I should be doing to monitor the battery to make sure there isn't some fault in the electrical system?
Old 05-20-2023, 02:55 PM #6
Real Name: Rich
Real Name: Rich
I would just make sure the terminal clamps are clean to ensure a good connection
Old 05-20-2023, 03:07 PM #7
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
It's either a battery cell failed or you have a bad short draining it.
A battery cell can fail in an instant. I have had this happen 2 or 3 times now.
To test. Have the battery fully charged and remove the terminals check the voltage. Let it sit a day or so with rerninals off and check it again. If there is a significant drop, the battery is junk. If it's at the same voltage the battery is most likely ok and you have a bad short.
Old 05-20-2023, 10:47 PM #8
HiLife HiLife is offline
The roads are really bad with deep pot holes roads where I am. And I had my share of a shorted cell on numerous wet batteries.
For testing, after having the battery sitting over night, without activating any lighting or voltage drain, a good rule of thumb of surface battery voltage is:
12.65 100% fully charged
12.50 90% charged
12.45 75% charged
12.35 60% charged
12.25 50% charged
12.06 25% charged
11.90 discharged
Old 05-21-2023, 09:11 AM #9
jross20's Avatar
jross20 jross20 is offline
jross20's Avatar
In case it helps anyone, I recently had an issue in which the truck would start but act kind of weird. So like the radio would turn on even though it was off, the air conditioner would make a weird noise, like the blower motor I mean. And then the very next time that I turned it on everything lit up, the headlights flashed and then the truck was totally dead. It ended up being one of the battery terminals. Even though it looked fine it basically has slowly disintegrated and it was only momentarily connecting.
So I would check your terminals too and make sure that they're not loose on the wire end.
Old 07-21-2023, 06:08 PM #10
Clickx Clickx is offline
Clickx is on a distinguished road
your battery 100%, otherwise it would be ground/ poor positive connection.
Clickx is offline   Reply With QuoteReply With Quote
Old 07-26-2023, 06:13 AM #11
enginelover enginelover is offline
enginelover is on a distinguished road
First thing I do is label the battery the day I get it with the warranty information because you'll forget all that. I write it on a piece of paper, often that's the back of a copy of the receipt, and then I fold it (to protect it) and tape it with clear packing tape onto the backside of the battery so that it's always there whenever the battery does fail.
Then you can coat the lead terminals and brass zinc-coated cable ends with dielectric goop, where it's often only the positive that gets those whitish greenish yellowish crusty deposits.
Also, I put a sheet of rubber from an old tire tube under the clamp to protect a tiny bit from vibration since the cells shaking loose their solids is what shorts out the plates as they fall to the bottom and fill up the space between the plates to the point that each plate shorted out lessens the open circuit voltage until finally the battery can suddenly die on you.
Every few months you pop off the cell covers to top off with H2O - if necessary - although if it takes a LOT of water, then you may need to charge it separately (but usually you don't need to put it on a charger).
If it sits for months, then you can trickle charge as needed.
Regarding the H2O... water is water... although city water is different from well water and every well has different chemical compositions too... but the question is whether or not those differences matter in terms of reality - realpolitik, so to speak. Sure they matter theoretically. But do they matter in real life use? I'm not convinced they do. Anyway, I used to use tap water for a long time but most people would scream bloody murder if they saw you use that. At the astute advice of a friend (who saw me use tap water), I recently started to collect rain water - which is essentially distilled water - and yes - I'm aware that if you live in a city - it may be even more acidic than rainwater normally is (rain is acidic from the carbon dioxide - not the sulfur dioxides which don't really exist anymore in any great measure). I use that rain distilled water for my clothes iron and car batteries (and for filling up the water in the summer windshield washer fluid with a dab of Dawn dish detergent). I'm not big on buying something that I don't see any real scientific information that matters if you bought it.
enginelover is offline   Reply With QuoteReply With Quote
battery , fuse , position , starter , turn
Weird parasitic draw, possible bad (new) battery? thegipper 3rd gen T4Rs 23 01-19-2023 08:46 PM
Replaced car battery, now A/C has weird smell??? AlexG General Discussions 2 11-22-2019 12:36 AM
Weird Issue - Tweeters popping after cleaning battery??? t-rex grrr Engines / Suspension / Wheels / Tires / Audio / Accessories 4 01-01-2018 05:06 AM
Weird battery drain issue - high temperature? AKmoney 4th Gen T4Rs 20 10-13-2015 02:30 PM
Weird starter/battery issues after wheeling xxaarraa 4th Gen T4Rs 13 11-13-2013 07:25 PM
