05-26-2023, 08:10 PM
#31
Real Name: Jerod
Real Name: Jerod
Originally Posted by 19963.4lsr5
What if an intake valve is hanging open?
I thought about that too. Having the injectors unsealed could give the air/fuel mix a shortcut straight to the throttle body. It's possible. I think he'd have some other major symptoms though.
05-26-2023, 09:15 PM
#32
Real Name: Robert
Real Name: Robert
I have a fairly negative opinion of these fuel injectors that supposedly have better spray patterns. I tried some injectors from Flamethrower and my truck ran like crap. He sent me another set and same result. I threw the stock injectors back in and it ran perfectly.
1999 Toyota 4Runner Limited 4x4 - Turbocharged Garrett 57-trim T3/T4 - URD AFR Sensor Calibrator - DW255 fuel pump - 7MGE Supra 315cc “lime green” fuel injectors - 231mm Tundra Brakes - B&M 70264 Transmission Cooler - Monitoring ATF Temps and AFRs With My iPhone - DIY Projector Headlight Retrofit - Cooper Discoverer AT3 - OME 906 Coils & Rancho 9000XL Shocks (Rear) - Airlift 1000 - RadioShack $5 Rear O2 Simulator
2000 Yamaha XR1800 Jet Boat - MR1 4-Stroke Engine Swap
05-27-2023, 01:15 AM
#33
Real Name: Jerod
Real Name: Jerod
Oh, that is surprising and unfortunate. The Flamethrowers in my 91 Pickup with the 3VZ-E engine did amazing. He sold so many of those sets. It even increased MPG's. Sorry to hear that the 5VZ-FE ones were no good.
05-28-2023, 09:48 AM
#34
official vendor
official vendor
I'm sending my original injectors to MotorWest to be cleaned, then will put them back in as soon as I get all the gaskets and crush washers delivered. Can't wait to see what that does to my LTFT (not to mention the fuel in the TB).
05-28-2023, 11:44 AM
#35
Originally Posted by Spiker Engineering
I'm sending my original injectors to MotorWest to be cleaned, then will put them back in as soon as I get all the gaskets and crush washers lined up. Can't wait to see what does that to my LTFT (not to mention the fuel in the TB).
I think it will fix your problem. Toyota definitely put that bottom oring there for a reason, it was even on both injector designs..
05-31-2023, 03:22 PM
#36
I think you'll be quite happy with the results... Stock Toyota/Denso fuel injectors are very reliable, but can get dirty. A good cleaning (not just a bottle in the tank) does wonders in those situations.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
05-31-2023, 03:36 PM
#37
Most of the good cleaning is replacing the inlet screens. They are a very low micron.
05-31-2023, 06:39 PM
#38
Real Name: Mark
Real Name: Mark
@ Spiker Engineering
Sorry for your woe's, Thanks for the possible What not to do thread.
Good info, Injectors are in my future Oside MotoWest experience worth hearing!
06-01-2023, 10:41 AM
#39
official vendor
official vendor
My pleasure, I'm always happy to share any good tips I learn along the way, even if its via the school of hard knocks.
I'm still withholding my final position on this until I get the cleaned OEM injectors back in, then we'll see .
06-01-2023, 05:06 PM
#40
My Saturn always runs negative fuel trims. -10 to -15 at idle to -3 to -8 while driving.
06-01-2023, 05:11 PM
#41
Yeah, watched mine because of this thread. ~-13 at idle and LT pretty much 0 at cruising speed, ST bounces around by 1 or 2 % as expected
06-02-2023, 09:26 AM
#42
official vendor
official vendor
Mine is pegged at -18%. I might have been OK with it if it weren't for two things: 1. it was right at 0% before the fuel injector change, and 2. fuel in the TB.
06-02-2023, 09:37 AM
#43
Plugging the idle air assist didn’t solve it I’m guessing.
06-02-2023, 09:50 AM
#44
official vendor
official vendor
I forgot to report back on that! I disconnected the hose, plugged the hose and capped the IAC valve tube, and drove around.
My LTFT didn't change (even after resetting the ECU). But the fuel in the TB was gone.
06-02-2023, 01:20 PM
#45
Real Name: Jerod
Real Name: Jerod
Have you noticed any difference in mileage with the new injectors? Or is the 4Runner garaged for now?
