Old 05-25-2023, 01:41 AM #16
socalkid's Avatar
socalkid socalkid is offline
socalkid is on a distinguished road
socalkid's Avatar
had a similar issue with my 98' back when I bought it almost 6 years ago though it was more high pitched but also not nearly as loud as in the vid of that 03' Tacoma. only happened with the pedal compressed/clutch disengaged just like yours. did a tranny fluid flush, had a couple shavings fall out and some time later it went away on its own so who knows. if you search my history I know I posted about it back when it happened. good luck with yours and hope you get it sorted.
1998 3RZ 5-spd Base 2wd - His
2019 TRD OR w/KDSS - Hers
socalkid is offline   Reply With QuoteReply With Quote
Old 05-27-2023, 06:32 PM #17
nathanroyse nathanroyse is offline
nathanroyse is on a distinguished road
I just read thru your old posts… did you ever come to a conclusion? Besides everyone saying it’s normal… because it’s definitely not lol. I pulled my transmission out yesterday just to double check everything, I took the pressure plate, clutch, and flywheel off, cleaned and retorqued everything. I noticed a little play up and down but also back and forth(in and out) on the input shaft.. if I push and pull on the input shaft it makes a small thud sound. Maybe 1mm of movement. Would this cause such a whine? I made sure everything went back exactly how it was when I put the internals back together but maybe it has wear elsewhere than the bearings?
nathanroyse is offline   Reply With QuoteReply With Quote
Old 05-27-2023, 07:28 PM #18
socalkid's Avatar
socalkid's Avatar
nah like I mentioned flushed the tranny and after maybe 6-9 months it went away on its own.
Old 05-27-2023, 09:57 PM #19
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Does your transmission input shaft feel smooth when shifting through the gears and neutral?
Lots of times, you can feel play and bearings going bad by spinning the input shaft or output shafts on transfers when separated
Granted, now it's back in, and you can't test it or feel it.
For example: I could feel the 3rd member ply and wear by spinning tires on Jack stands.
Lots of times you can feel bad bearings the exact same way with the shafts.
Old 05-28-2023, 03:05 PM #20
Yeah it spins fine. Like I said it has all new bearings. Makes the sound in all gears except 4th. When I had the transmission out of the cases I put it in all gears and spun it and it was perfectly smooth.
Old 05-28-2023, 03:56 PM #21
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
You have an issue straight through then. I wasn't sure if you were inside the transmission or not. To me, this is extremely odd. Let's see if @badluck has any ideas. He is very busy at the moment, though. So, he.may not have time to respond..
I am thinking of an output shaft pilot roller bearing or the rear bearing in the input shaft. However, I am guessing. Being you replaced the pilot, it's definitely internal at this point.
Old 05-29-2023, 12:46 AM #22
I appreciate the time and thought you put in to all of these posts. Since all of the internal bearings have been replaced I’m beginning to think something else is wearing… from the research I’ve done, I found that the “bearing retainer” on the inside can sometimes experience wear causing the main shaft to come out of alignment which results in poor shifting performance… doesn’t say anything about noise tho. I think there’s also 2 more sets of needle bearings under the gears that didn’t come with the kit. Those could be wearing and causing the noise but you would think that if they knew that was a common failure point they would be included in the rebuild kit. I’m trying to gather as much info as possible before I tear into it again because I really want this to be the last time.
Old 05-29-2023, 06:41 PM #23
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I am sorry i cant be more help. I just never had any issues with 5 speed Toyotas. The 1983 5 speed that i did have issues with I had the rear bearing replaced but the entire transmission was full of shavings. I just replace it due to the damage that was severe with a used one that was good. My 2 manual 4 runner 5 speeds so far are solid.
Only a handful of people will open them up a manual transmission so I am glad you are one that will. As a guess, I would agree that its a part that was not replaced is causing the issue or something is out of spec.
I am just curious how many miles in on this 5 speed transmission? Maybe you stated and i missed it if so i apologize.
Old 05-29-2023, 07:03 PM #24
No worries. I will get to the bottom of it. It has 143,000 miles total. 140,000 in the original car and 3,000 in my car. I have some pictures from when I opened it I’ll post them when I get back home
Old 05-29-2023, 10:38 PM #25
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Hmm.. I have many manuals since the early 90s. I haven't had any transmission issues and the 2 have now has 220k and my other is 120K.
Oh.. Yours is a transplant. That really shouldn't matter I am really surprised you are having any issues with that low of miles. I was thinking more like 300 to 500 k miles.
Mostly you keep the gear grease clean mostly these transmissions out last the rigs. Interesting indeed.
Old 05-29-2023, 11:29 PM #26
TucsonMike TucsonMike is offline
TucsonMike is on a distinguished road
Here's a,thought....since ur saying there's no noise in 4th gear, to me this is clue that possibly it could be an issue with the counter shaft. When u r in 4th gear I don't think there's a load on the counter gear like there would be in the other gears. Maybe google that symptom and see if that sheds any light into the situation. I have worked on American truck transmissions and tcases but haven't had to do any work on my 4runner 5speed with over 300k. I did have a similar situation on a tcase once where I replaced all the bearings and it still had a rolling knocking noise. The problem turned out to be that the ID of the gear that rode on roller bearings was worn. Once I replaced that gear, my noise went away. I also wouldn't rule out a worn part but unless u have the tools and specs/wear limits, that would be hard to figure out.
I also assumed u used good quality bearings and they were identical to the ones u replaced.
What were the bearings u mentioned that didn't come with the rebuild kit?
To me it sounds like a bearing noise as well.
Good luck and hopefully if u figure it out, you'll let us know.
MikeM
TucsonMike is offline   Reply With QuoteReply With Quote
Old 05-30-2023, 04:21 PM #27
Clutch sound
Yeah I’m not sure of the maintenance the previous owner did on it. I know the car sat for about 4 years before I bought it and swapped the transmission into my car. But the donor car sat at 140,000 miles when I took it out. I barely drove the car so I can’t remember if it was making that sound in its original car before it went into my car… I think it was. The oil that I drained out was not bad at all though.
Old 05-30-2023, 04:41 PM #28
MikeM
I bought the kit off of cobra transmission. Here is the link to the exact kit I got:
R151 Standard Transmission Bearing and Seal Kit | Toyota Pickup, Tacoma, 4runner, T100, Tundra - Cobra Transmission
I think they’re good quality? They were Nachi.
The ones that weren’t included were the ones that sit on the main shaft under the gears. They’re like needle bearings. Or atleast that’s how I would describe how they look
Old 05-31-2023, 04:30 PM #29
I’m not really sure if these photos will help at all but I took them when I first pulled it apart. Notice the amount of metal(no chunks) on the magnet at the bottom.
Old 05-31-2023, 05:16 PM #30
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Yes you have quite a bit of metal paste in there... definitely something heavily warn in there. Did you check everything when you have it apart? The FSM has what to check and verify in its manual Transmission section.
clutch , completely , issue , pressed , sound
Does this sound like A/C Compressor clutch? 92Pony 3rd gen T4Rs 14 12-24-2020 10:10 AM
V6 fan clutch sound? grave 4th Gen T4Rs 0 04-21-2017 05:30 PM
Clutch sound Foureigner 3rd gen T4Rs 1 06-09-2010 09:03 AM
Clutch sound GSMNP125 Classic T4Rs 7 03-31-2010 12:49 PM
sqeaky clutch sound? 808FO-RUNNAH 4th Gen T4Rs 3 03-07-2008 03:32 AM
