Old 05-22-2023, 07:55 PM #1
nathanroyse nathanroyse is offline
nathanroyse is on a distinguished road
Clutch sound
Anyone have any idea of what could be causing this sound? This is not my video but I am having the same issue. The sound completely goes away when the clutch is pressed in.
2003 tacoma transmission sound - YouTube
May 11, 2023 - YouTube
nathanroyse is offline   Reply With QuoteReply With Quote
Old 05-22-2023, 11:02 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Sounds like the a bearing going bad. Doubt its pilot bearing. Granted throw out bearimgs mostly squeak and noisy when engaged.
I am leaning more towards a bad pressure plate and clutch. In the audio above. However, this is just a guess.
Old 05-23-2023, 12:14 AM #3
That’s what I thought at first, I think you helped me out a couple times on my other post about this. However, I just replaced all bearings and seals in the transmission with no change in the sound. Clutch and pressure plate are brand new oem. The flywheel is brand new LUK from yotashop. I really don’t know what else to look for
Old 05-23-2023, 12:19 AM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Oh dear. As this is sounding to me like a bearing failing.
If it's not those, that's not good. Does it Make the same sound with the transfer case in Neutral?
Old 05-23-2023, 02:26 AM #5
Yeah. That was quite the job and unfortunately it didn’t fix anything. I’ll check tomorrow about the transfer case. I have a feeling it’s gonna make the same sound because of how related to the clutch position it is.
Old 05-23-2023, 09:11 AM #6
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
The transmission is neutral. So that's something in the driveline.
How does the gear grease look like in the transfer and the transmission? Any flakes?
Did you put the clutch in the proper way. As it's the opposite of what it states on the clutch , it can fit both ways.
Old 05-23-2023, 02:27 PM #7
Clutch sound
The gear oil is brand new. I replaced it with MT-90 after I did the rebuild in hopes of fixing the issue. The transfer case is brand new 75w-90 as well.
No flakes but there was a little more metallic sludge on the magnet in the transmission than I would’ve liked to see. No big chunks or anything I could feel when rubbing my fingers together.
The clutch didn’t come with any instructions but I put the bigger part towards the engine as seen in Timmy’s video. Correct me if I’m wrong.
I just started it with the transfer case in neutral. Same sound. I shifted through all the gears with the transfer case in neutral and it makes the whine sound in every gear except 4th.
Old 05-23-2023, 03:29 PM #8
chapolito's Avatar
chapolito chapolito is offline
chapolito will become famous soon enough chapolito will become famous soon enough
chapolito's Avatar
I have this same sound, interested to learn what the cause might be.
I also get a similar, but louder and that's-not-right sounding (kind of a hunting + rubbing sound) when I take my foot off the gas but leave the clutch engaged. Do you also have that?
chapolito is offline   Reply With QuoteReply With Quote
Old 05-23-2023, 03:34 PM #9
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Timmy Video is correct on clutch orientation. He follows the FSM..
Old 05-23-2023, 04:51 PM #10
It is so annoying! Umm I don’t understand what you mean, are you saying that when your driving in say 4th gear and take your foot off the gas it makes the sound? If I have the clutch pressed in and press the gas a little bit and let the clutch out it makes a sound like that. Like a bearing has to spin really quickly for a second to get to the same speed. I’ll try to replicate what you’re talking about and get back to you. When did yours start making this sound?
Old 05-23-2023, 04:54 PM #11
Good. I have heard that some of them go in backwards too. You’re making me question that now since the one used in the video was not oem. I had a friend put his in backwards and he said that he couldn’t depress the clutch at all to change gears so I think it’s in the right way.
Old 05-23-2023, 06:40 PM #12
chapolito's Avatar
chapolito's Avatar
Yes, like I'm rolling up to a light and I take my foot off the gas, then I get the sound, but also a more rumbling/hunting sound in addition. Hard to explain. Except that I usually notice it much more in 2nd/3rd while 4th tends to be smooth/quiet.
Just tested with the transfer case in neutral and also got the sound in all gears except 4th...strange!
Old 05-23-2023, 06:54 PM #13
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Oh boy.... mostly in Toyota 5 speeds 4 is direct through.
So if forth is the only quiet. You boys may have transmission issues with bearings starting to fail inside.
I have never seen a Toyota manual Transmission go bad that wasn't extremely abused. Granted mine around here chassis never made it past 250k in those days.. I didn't do alot to stop rot years ago...
Neutral would be the input shaft spinning.
In all gears, your output shaft is spinning.
Any Toyota or manual transmission experts around your locations? They maybe able pinpoint exactly where your issues are.
Old 05-23-2023, 08:28 PM #14
So this is what a mechanic told me, I replaced all the bearings and I still have the sound… what else could it be?
Old 05-23-2023, 08:30 PM #15
I don’t think I have that one. I do have a grind in my clutch petal ONLY when I press it to shift above 3500 rpm in all gears. I don’t want to keep throwing money at this stupid thing without knowing if it’ll even fix the problem haha
clutch , completely , issue , pressed , sound
Does this sound like A/C Compressor clutch? 92Pony 3rd gen T4Rs 14 12-24-2020 10:10 AM
V6 fan clutch sound? grave 4th Gen T4Rs 0 04-21-2017 05:30 PM
Clutch sound Foureigner 3rd gen T4Rs 1 06-09-2010 09:03 AM
Clutch sound GSMNP125 Classic T4Rs 7 03-31-2010 12:49 PM
sqeaky clutch sound? 808FO-RUNNAH 4th Gen T4Rs 3 03-07-2008 03:32 AM
