Old 05-31-2023, 10:18 PM #16
infamousRNR's Avatar
infamousRNR infamousRNR is offline
infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light
Originally Posted by phattyduck View Post
Red and Pink from Toyota are compatible. Red requires dillution for 50/50, Pink is premixed.
If you add Pink to a Red system, you have to keep the shorter Red change interval, but nothing else needs to be changed.
TSB PG010-02
There are some later subtleties with the right FIPG to use with each coolant, etc. which doesn't apply to the 5VZ.
good points here.. we ( @mtbtim ) got a print out from Toyota today saying a 2001/2002 takes the longlife PINK... and they tried to look up 96-00 but it didn't have a definitive statement in their system like the 01/02 had...
I think we chalked it up to the style of head gasket the different years use and the different style coolants can not be compatible with the 2 diff coolants....
I think the general consensus here in this thread is both will work, but with any coolant change, you want to have multiple rounds of flushing the coolant system with distilled water before you put a different style coolant in.
I mixed Zerex Cooling System Antifreeze Coolant with my existing mix or red and pink in my truck after a radiator failure and it worked fine but would recommend using a consistent coolant rather than mixing a bunch of different types.
1998 Desert Dune Toyota 4runner Limited 4x4 w/ factory e-locker
2000 BLACK Toyota 4runner Limited 4x4 w/ factory e-locker Build Thread
2002 Thundercloud Metalic Toyota 4runner Limited 4x4
Build Thread
infamousRNR is offline   Reply With QuoteReply With Quote
Old 06-06-2023, 03:39 AM #17
Pyral's Avatar
Pyral Pyral is offline
Real Name: N/A
Pyral has a spectacular aura about Pyral has a spectacular aura about
Pyral's Avatar
Real Name: N/A
My mechanic put green in when I got a new radiator and I want to go back to red.
Is there any merit that tap water can cause an iron block to rust from the inside out?
How many times should I flush the system before I add the coolant?
And will flushing the system out also help my heater core? (I don't have any issues)
Either way I'm using distilled water. I do know that pure water does tend to run cooler than a 50/50 mix, but you have to worry about freezing. Pure coolant will freeze at a higher temperature than a diluted mixture too btw.
1998 4runner 2.7 manual
Pyral is offline   Reply With QuoteReply With Quote
Old 06-06-2023, 12:24 PM #18
fourfive's Avatar
fourfive fourfive is offline
fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough
fourfive's Avatar
I think recommendation of avoiding tap water is due to the risk of accumulating mineral deposits that could create issues in the cooling system. As for the heater core, the important thing is to make sure you get all the air out of the system.
My thoughts, use distilled water if you are able to. If distilled water isn't available, flushing with tap water is probably better than running a dirty system. Flush until the water coming out is clear or clear enough. My experience has been about 4x before the water looked mostly clear.
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
fourfive is offline   Reply With QuoteReply With Quote
Old 06-06-2023, 12:45 PM #19
Basically the same as distilled water - but only if you leave it in there alone!
I have left water only (distilled) in a cooling system for a week or two (while testing things after motor swaps, knowing I'll very soon be swapping out to coolant) with no ill effects.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 06-25-2023, 12:36 PM #20
amalik amalik is offline
amalik is on a distinguished road
Fwiw I use Zerex red Asian vehicle with no issues
amalik is offline   Reply With QuoteReply With Quote
aluminum , coolant , engine , pink , red
Toyota Red vs. Pink Coolant T4R_Finally 3rd gen T4Rs 38 07-31-2023 05:21 PM
Mixing Toyota Pink coolant with universal: Recipe for disaster? Napalm 4th Gen T4Rs 19 09-09-2022 04:01 PM
Toyota pink coolant eats away at water pump gaskets? anonymousgromers 4th Gen T4Rs 18 10-08-2018 11:25 PM
Toyota long life coolant Pink genuine drg007 For Sale: T4R Items 0 12-10-2014 02:12 AM
Toyota Red coolant vs. Toyota pink pre mixed jreask 3rd gen T4Rs 23 11-15-2013 01:54 PM
