Originally Posted by phattyduck
Red and Pink from Toyota are compatible. Red requires dillution for 50/50, Pink is premixed.
If you add Pink to a Red system, you have to keep the shorter Red change interval, but nothing else needs to be changed.
TSB PG010-02
There are some later subtleties with the right FIPG to use with each coolant, etc. which doesn't apply to the 5VZ.
good points here.. we (
mtbtim
) got a print out from Toyota today saying a 2001/2002 takes the longlife PINK... and they tried to look up 96-00 but it didn't have a definitive statement in their system like the 01/02 had...
I think we chalked it up to the style of head gasket the different years use and the different style coolants can not be compatible with the 2 diff coolants....
I think the general consensus here in this thread is both will work, but with any coolant change, you want to have multiple rounds of flushing the coolant system with distilled water before you put a different style coolant in.
I mixed Zerex Cooling System Antifreeze Coolant with my existing mix or red and pink in my truck after a radiator failure and it worked fine but would recommend using a consistent coolant rather than mixing a bunch of different types.
