Old 05-28-2023, 08:15 PM #1
RodrickHeffley's Avatar
RodrickHeffley RodrickHeffley is offline
RodrickHeffley has a spectacular aura about RodrickHeffley has a spectacular aura about
Sunroof Mount Holes leaking
I thought it was my drain leaking, but I pulled down the headliner in the corner and found this part to be leaking.
this isn't mine, but it illustrates where the leak is coming from.
I tried putting silicone over the holes up top but that didn't seem to do much. what should I try next?
1998 4Runner Limited 4WD w/Rear Locker
281k Miles
Build Thread
RodrickHeffley is offline   Reply With QuoteReply With Quote
Old 05-30-2023, 10:29 AM #2
aontkos's Avatar
aontkos aontkos is offline
aontkos will become famous soon enough
aontkos's Avatar
I pulled my headliner and drove without it for a while and noticed drips coming from the exact same spot. A few years back, I had vultures eat the rubber weather stripping around my sunroof glass, which seemed to allow water into the rubber, and it would eventually drip from there. I'd be willing to bet the rubber around your sunroof is compromised somewhere.
Since the rubber can't be replaced, I got used sunroof glass from Ebay. This fixed the problem. It was $100 well spent, especially after spending so much time sealing my roof rack mounts and tidying things up. I had noticed a musty smell in my truck in the past and now those musty smells haven't returned.
aontkos is offline   Reply With QuoteReply With Quote
Old 05-30-2023, 12:02 PM #3
interesting, i didn't think it'd be the glass, i do know there's a hole in the rubber in the front that i tried to seal with the same silicone. if that doesn't work i know where to look next
thanks!
281k Miles
Build Thread
Old 05-31-2023, 09:36 AM #4
brillo_76's Avatar
brillo_76 brillo_76 is online now
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
thanks!
I have one that leaks through the glass seal. So one out of 5 leaking through the glass seal. That's 20%
brillo_76 is online now   Reply With QuoteReply With Quote
Old 05-31-2023, 10:08 AM #5
Yeah that is a pretty low percentage, however the hole on the rubber on my sunroof was pretty big, which made sense to me as to why it'd be leaking.
Have you found the leaks (if there are any) on the other four?
281k Miles
Build Thread
Old 05-31-2023, 12:15 PM #6
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I think I have another that that the drains maybe plugged.
holes , leaking , putting , silicone , sunroof
Leaking Sunroof Tip For Clearing Clogged Drain Holes bernardmwrangle 5th gen T4Rs 9 06-26-2019 01:32 PM
Water in roof rack mount holes CentcomPete 5th gen T4Rs 13 06-13-2019 09:25 AM
nudge bar mount holes for vzn130??! co_ree Classic T4Rs 0 05-05-2014 01:31 AM
Broken sunroof leaking. mattf485 3rd gen T4Rs 10 04-07-2014 10:41 PM
Sunroof Leaking mdominic 3rd gen T4Rs 7 05-23-2011 08:08 PM
