06-02-2023, 05:12 PM
#16
Real Name: Rich
Real Name: Rich
I've had a Tekonsha since we got the travel trailer in 2/2014. Never had a problem with it. Glad to hear you've been able to make everything work.
Rich
2004 V8 4Runner 140K+ miles
Kentucky
06-02-2023, 08:16 PM
#17
Where are y'all mounting your 7 pin connector? I've currently got mine on the left side of the hitch but it's pretty far away and I ran into an issue with too much tension on the cable on a really sharp turn. I'm contemplating mounting it in the bumper but looking at it I don't think I could get to the back side to cinch down the nuts. I'd probably have to use self tappers and I'm not sure about that long term.
06-04-2023, 10:43 AM
#18
Stainless Steel tappers what I'd look for they out there if fighting rust, layer of 3M doubleside tape.
Got chrome bumper polish SS. Most load is plug n unplug rigged right.
06-04-2023, 09:40 PM
#19
Yeah, I would definitely use stainless steel. I'm more woried about them working loose after repeated pluging/unplugging. I've been looking at the bumper trying to find a way to get a socket back there to tighten down a nut and washer but it appears to be multiple layers and I'm not sure I could do that. Right now I'm trying to find a plug end that will work with the bumper's curve. I might have to just use some heat and try to mold it it fit better.
At first I wanted to just screw/bolt it into the hitch itself but it's some thick steel and I didn't have any luck trying to drill a pilot hole.
06-04-2023, 10:05 PM
#20
Redarc has to be the most simple controller to use and install , works great
Sent from my iPhone using Tapatalk Pro
06-05-2023, 08:52 AM
#21
@ poisedforflight
, fine thread self tappers for thinner metal what's held the OE 4 pin in place
next easiest RivNut, welded nut strips like used to mount hitch to frame.
06-05-2023, 11:53 AM
#22
@ poisedforflight
Thanks, I'll give it a shot.
06-05-2023, 01:59 PM
#23
I used this: Just a moment...
Modified for a bit more clearance and to mount in the stock 4-pin mount location. Its tight, but I didn't want the larger connector to eat up much of my off road clearance. The main plug is standard equipment on many newer trucks, so easy to get a replacement at a parts store if needed in an emergency.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
06-06-2023, 07:11 AM
#24
Originally Posted by phattyduck
Thanks, can see that working lotta places covering both bases.
06-07-2023, 09:27 PM
#25
Can you post some pictures of your setup?
06-08-2023, 01:33 PM
#26
I went the lazy way since I don't tow that often with it (like once a month).
I have a long isolated wire "sausage" that I just tuck back in the rear left square compartment. I like that I don't loose clearance and it will never rust or corode.
Ask if you need any picture but it's pretty simple.
When using, I close the backdoor over the wire "sausage" and that's it. My english sucks today but the "sausage" is just a tick, soft and transparant silicone-like tube where my trailer wires are routed. Comes with brake controller plug kits.
Been like that for years and now upgraded from 4 to 7 pins.
1998 4runner SR5
06-09-2023, 03:28 PM
#27
Here ya go...
Connector mounting:
Controller interface:
Controller box (looking up above driver's left foot location):
The grey wire that comes through the waterproof grommet on the firewall is a dual jacketed 10 gauge wire that I'm using half for brake controller power/signal and half for a trailer charge wire. I'm on my third trailer adapter box in the back, even though I don't tow all that often...
06-09-2023, 05:30 PM
#28
Here ya go...
Connector mounting:
Thanks, that looks exactly like what I want to do. That plug is expensive but it looks like it will be worth it if I can use the factory mounting holes.
I also have a RedArc, it's been great so far.
06-09-2023, 08:46 PM
#29
I have my 4 pin connector tucked and tied up high on the frame behind the bumper. I use an extension cable when I need to tow. When I go to a 7 way, I will actually just add another 4 way cable and build an extension harness for the 7 way plug when I need it. I anticipate needing it 5 to 7 times a year, so this seems the simplest way in my mind. I already have power running to the back from the battery, so I just need to tap into the brake wires and run 1 more back there. A 7 way actually uses onlyl 6 of the 5 of the 7 pins. 4 for the standard trailer lights, and 1 additional for the trailer brake signal. The other 2 are for constant power to recharge batteries, etc and for reverse lights if you have them.
The 4Runner Show
06-14-2023, 03:23 PM
#30
Here ya go...
Connector mounting:
I ordered the plug/bracket/pigtail you recommended. Could you elaborate on the modifications you did to it?
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
