Old 05-29-2023, 10:00 PM #1
Pyral's Avatar
Pyral Pyral is offline
Real Name: N/A
Pyral has a spectacular aura about Pyral has a spectacular aura about
Pyral's Avatar
Real Name: N/A
Rear brakes dragging badly
I upgraded the center console and I had to remove my parking brake lever. I reattached the cable and had the same number of threads showing on the lever. But when I jacked the car up and turned the rear wheels I could still hear dragging even though the brake should be disengaged.
Today I completely loosened the e-brake cable until it was slack to make sure I hadn't made a mistake. But I can still hear pretty bad brake drag, here is a video. What is going on and how can I fix this?
1998 4runner 2.7 manual
Pyral is offline   Reply With QuoteReply With Quote
Old 05-29-2023, 10:23 PM #2
Reinout's Avatar
Reinout Reinout is offline
Real Name: Reinout
Reinout will become famous soon enough Reinout will become famous soon enough
Reinout's Avatar
Real Name: Reinout
Today I completely loosened the e-brake cable until it was slack to make sure I hadn't made a mistake. But I can still hear pretty bad brake drag, What is going on and how can I fix this?
This might not be an issue at all: try putting the wheels back on because the drum isn't squeezed to the rest of the mechanism. But:
Did you adjust the cable at the parking brake lever end or the drum brake end? It could have happened that while working on the 4Runner that the adjustment inside the brake drum got too tight.
Check out @mtbtim 's video. I have it starting from where he goes into that component. : Drum Brake Shoe Replacement - YouTube
1997 4Runner SR5- ~376k Miles and counting - 5 Speed E-Locker
2007 4Runner Limited V6- 165k Miles - Automatic - Brake Controller
2011 VW JSW TDI- 130k Miles - 6 Speed - Air Lift 1000
2006 Scamp trailer 16'
Reinout is offline   Reply With QuoteReply With Quote
Old 05-29-2023, 10:24 PM #3
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
The shoes seem to be adjusted on the tight side but you want a good amount of drag on the system so the brake pedal doesn't go to the floor. How does it spin with the wheel on? Did you yank the lever so much that you heard clicks on the rear end? This looks ok to me but I could be wrong so lets see what others have to say on this.
2000 4Runner Limited 4x4 V6
Old 05-29-2023, 10:46 PM #4
the_welfare_wagon's Avatar
the_welfare_wagon the_welfare_wagon is offline
Real Name: Rich
the_welfare_wagon will become famous soon enough the_welfare_wagon will become famous soon enough
Real Name: Rich
I had issues with this as well. My Ebrake however worked fine and I just pulled it like 40-50 times to make sure they were at the optimal tightness because once it’s “tight” the adjuster will just slip off the bell crank so you can’t ever overtighten them that way.
I’d drive them as they are currently and hit highway speeds for like 15 or so mins. Try your best to coast to a stop using the brakes as little as possible and then get out and feel the drums. If they are crazy hot you need to loosen them a bit.
DONT put much force on your fingertips when touching them either you’ll lose your fingerprints if they are crazy hot, ask me how I know Rear brakes dragging badly that’s when I decided to just fix my Ebrake
Obviously some heat is fine depending on how much you just used the brakes but when mine were too tight they boiled water I poured on them after a 20 min drive
96 Limited: 380k+ 255/85s Geolander MTs, Ironman Nitro 2" lift, Toytec 9602HD W/FJZ80 Shocks
the_welfare_wagon is offline   Reply With QuoteReply With Quote
Old 05-29-2023, 10:59 PM #5
brillo_76's Avatar
brillo_76 brillo_76 is online now
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Just changing the center console bracket causing this dragging... Hmm... If your bell cranks are not freezing and I believe you in a rust free area. Since you didn't mess with the rear drums this isn't adding up. I would back off the nuts 2 or 4 turns and see if that dragging goes away. If you look closely, the old plate is in the center. The 99 and above move the cable over just slightly so its possible that your cable needs to be slightly looser if you had it perfect before.. :-)
brillo_76 is online now   Reply With QuoteReply With Quote
Old 05-29-2023, 11:05 PM #6
diverscale's Avatar
diverscale diverscale is offline
diverscale will become famous soon enough
diverscale's Avatar
look at your bellcrank adjusting bolts. They may be over-adjusting. It's 1MM from the bellcrank, one each side.
Maybe the parking brake didnt REALLY release all the way before, and releasing the cable made the bellcrank finally going all its course (over 1mm) and over adjust. Have a look at that, takes a few minutes.
You'd have to back off the brake pads using the hole on the back plate if that is the case.
edit: just looked at the video, it isn't as bad as I thought, but I'd back it off until there is very very little to no drag at all, once your adjusting bolt is at 1MM. Self adjustment will take care of the rest.
1998 4runner SR5
diverscale is offline   Reply With QuoteReply With Quote
Old 05-29-2023, 11:06 PM #7
HiLife HiLife is offline
That looks fine to me too as is. If the drums stopped spinning immediately when you pulled your hand away, I would think that was too tight.
You could loosen up the star wheel and loosen the shoes but, the auto adjust will tighten the shoes back up again. Besides having a loose rear brake affects overall braking. Especially when running Tundra calipers up front.
Old 05-29-2023, 11:10 PM #8
diverscale's Avatar
diverscale's Avatar
Talking
That is one of the main reasons I always have a cheap laser thermometer in the garage! Testing brakes without actually touching them
1998 4runner SR5
Old 05-30-2023, 12:23 AM #9
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
This is with a slack cable, I loosened the nut as much as I could without having to run the end of the cable through the parking brake lever again. When I did the swap I also swapped the parking brake and the metal tub in runs through (even though it was identical to my 1998). I suspect this was always a problem, I just never tested it until I did this work.
I did remove the drum before this and I loosened the brake by a single gear tooth (I had watched the timmy video). I removed the drum because the brakes were dragging, so this didn't cause my issue.
I am correct for thinking that drum brakes shouldn't drag at all? These aren't disc brakes, they have springs inside them to pull the shoes inwards away from the drum. I'm mainly doing this because dragging brakes means less efficiency. Also this is a non-ABS 4runner if that matters, it has an LSPV.
Old 05-30-2023, 08:55 AM #10
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Ah. They will drag a little if they are set up properly. So your trying to eliminate this as and have them freewheel some. This would be super easy to accomplish in the rust belt as the bell cranks naturally seize up and the cable can stick.
Man the only way I know to do this would be to remove the arm that runs the adjustment.
Then you have to manually adjust your rear brakes.
Old 05-30-2023, 03:08 PM #11
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
So I reattached the parking brake cable the way I had it, and there is little difference in how it feels. A slack cable feels just about the same to me.
Here's a quick video I took after I set the cable back up, it was harder to spin the drum forwards with one hand than backwards. I made another video spinning the hub in the other direction since I needed both hands free to do it.
I understand why disc brakes drag, there is nothing pulling them away. But why would drum brakes rub, isn't that what all the springs are there for? What is the normal amount of drum brake rub?
Old 05-30-2023, 07:27 PM #12
diverscale's Avatar
diverscale's Avatar
too much drag. Have you done step one of this post #11 here for more clarity? (0.4 - 0.8mm)
https://www.toyota-4runner.org/3686135-post11.html
1998 4runner SR5
Old 05-31-2023, 01:28 AM #13
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
I haven't checked the bell crank, I'll do it tomorrow.
Can I loosen the brake adjustment mechanism and pull the hand brake repeatedly to get it back into proper adjustment?
Old 05-31-2023, 08:33 AM #14
Real Name: Rich
Real Name: Rich
Yes that’s what I did cause trying to find the proper drag by moving the bell crank was annoying
Old 05-31-2023, 08:13 PM #15
diverscale's Avatar
diverscale's Avatar
yes - IF the bellcrank adjustment bolt is properly adjusted in the first place. Just loosen it until it stops dragging completely then readjust with handbrake
When you'Re done, you can jack the rear, put car into drive, and test both your handbrake and foot brake using your mirrors, you have to look if both wheels stop, no need to use gas(throttle) (don't know if your 4 cyl have tires wide enough so you can see with your mirrors but, you'll know if it's the case)
****** IF your wheels or one of your wheel don't stop, put car into neutral and wait for the tires to stop spinning before putting in park******
1998 4runner SR5
brake , cable , hear , lever , rear
brakes dragging on my 99 Help Johnnie 3rd gen T4Rs 11 04-14-2023 09:22 PM
Front Brakes dragging tristero 5th gen T4Rs 10 06-16-2018 11:28 PM
Brakes Dragging? FlyNavy 5th gen T4Rs 7 04-14-2011 03:02 PM
Brakes dragging on all 4 wheels jimkmi 4th Gen T4Rs 1 04-09-2011 09:47 PM
95 brakes dragging slipknoter106 Classic T4Rs 1 03-20-2011 11:12 AM
