Originally Posted by hawkcharmer
Hello,
Just picked up 8 Harbor Freight LED Rock lights. I will only use 7 lights.
Each light is 4.4W each, about 0.42A each
30.8W total / 2.94A total
I was thinking of running all 7 lights to battery or my 6 blade blue sea fuse block under the steering wheel and using factory OEM toyota switch.
I will also be using 16 Gauge wire. This should be fine. The runs are not that long
The switch is 21 Amp at 14 Volts DC.
Will I be fine running it like this or do I absolutely need a relay?
Any feedback is greatly appreciated. Thank You
You don't explicitly "need" one, but having a relay at least in my eyes completely separates the circuit so you won't have any draw or other problems with amperage
1998 4Runner Limited 4WD w/Rear Locker
281k Miles
Build Thread
