Originally Posted by phattyduck
LED light pods (at least, anything in a normal price/size range) use much less power than the original halogen lights. The original wiring (gauge/fuse/relay) is fine. Make sure you verify/fix the possible wiring issue mentioned above.
I checked and it appears that this is all working up to snuff, didn't hear any clicking from the relay when pulling it (was probably the first time it had been pulled since the install and it was a bear to get out, hit it with some dielectric grease before putting it back in). I think I'll go ahead and order up those lights then. Anyone have any ideas though on how to uncouple it from my brights? Also how do I test which leads are positive on the Hella harnesses (I plan to splice the lights into those harnesses) Could I just take a multimeter and test each lead to ground for current?
