10-03-2012, 10:21 PM
Suspension rattling and clanking sounds
So my lift is in the sig.....the rear end has a slight squeak or rattle at times and I've come to just deal with that but the front end is what is starting to really bother me.
It usually happens when the suspension is off kilter, like going over a slightly uneven road or when there's an "S" curve in the road and my steering switches from turning left to turning right. That's about the best I can describe it. The front end has this slight metal on metal sound almost like its adjusting or something. Ivemchecked everything I possibly could and even stopped, got out, and shook the truck as hard as I could but heard nothing.
Has anyone else had this or something similar?
‘14 SR5 in white
Front: King ext travel 2.5 w/ adjusters, TC UCA/LCA
Rear: King 2.5 shocks w/ adjusters, Dobinson’s 3” Icon Billet lowers, Icon tubular uppers, PCK
Wheels/Tires: SCS SR8’s w/ Toyo MT 35x12.50x17
Full RCI skids
10-03-2012, 10:29 PM
Real Name: Isaac
Real Name: Isaac
steering rack bushings, sway bars, upper or lower control arms, panhard bar idk lose shock mount(doubt that though). it also could be one of the isolator bushings for the top hat on the struts... i had this on my 4runner, id hear this clunk every now and again but it was more from going over bumps but it was not a constant clunking sound... sometimes it made the sound sometimes not
if a*sholes could fly this place would be an airport -2004 GX470 spm -97 SR5 3.4, SCS Stealth 6's w/305 70 17s MTRs, Icon 2.5" RR w/700#coils, OME861s w/Icon tacoma 2.0 RR, ARBs w/nitro 4.88, PIAA LED lights, 170amp CS144, ARB snorkel, ARB bumper w/xd9000ce, CBI swingout loaded, BudBuilt skids, lil skip tank skid, sliders, LCE 231s(d&s), first gen roll bar mod, LED interior/dash lighting, B&M 70624+perma cool w/electric fan, dual electric fanshttp://www.toyota-4runner.org/3rd-ge...ld-thread.html
http://www.metaltech4x4.com/
10-03-2012, 10:33 PM
Yeah it's not all the time, just occasionally. And usually when it does it I've got the wheel just slightly turned. But then I'll hit a bump in the road and no sound whatsoever.
‘14 SR5 in white
Full RCI skids
10-03-2012, 10:36 PM
How are your front sway bar links?
10-04-2012, 10:55 AM
As The Kid said, it's likely a suspension component that's not tight. I had some front end clunking that turned out to be my sway bar end-links (both were loose)... I have also had my rear track bar bolt come loose... then fall out.
2014 4Runner Trail Edition Premium - Magnetic Gray
2001 4Runner SR5 Thread...Sold
2010 Bernese Mountain Dog
1998 4Runner Limited: Smooshed on an icy bridge in MT
10-04-2012, 12:28 PM
i've had an annoying squeak for about a month now because i'm too lazy to lift the truck up and rotate the spring 1/8th of an inch in the seat so it sits properly... there's a whole myrid of things that can cause what your describing , try to recreate the condition in such a way where you can have a buddy stand there and listen to where it's coming from, usually just jumping on the bumper will help narrow it down, with the wheels turned and a clunk i might suspect steering rack bushings..... if this is the case, climb under the truck and have a buddy move the wheels left to right and watch the rack in the bushings and look for play and slippage as it's doing it's thing.
'76 FJ40, '87 4runner, '98 LC 100, 99 4runner,'02 Tundra,'02 LX470,'08 Tacoma Dbl cab,'09 LC200, '16 Trail Premium. also 76 super beattle,'06 XR650L,'18 Triumph Scrambler-XE.
10-04-2012, 01:20 PM
i dont know if mine is the same but i also hear a bang (metal on metal). it bugged me for a month until i found out wat it was. my roof would bang up against those 3 small bars on the roof rack. prob not the same, just offering my 2 cents.
2001 4runner
4x4 sr5
10-04-2012, 01:44 PM
Moderator
Real Name: Waldo
Moderator
Real Name: Waldo
Turn your wheels slightly (try this turned both ways), grab your front bumper somehow and start trying to bounce the front end. If you hear something, have someone do the same thing while you investigate. You can't be a pansy about it (not saying you are lol) but you need to really lay into it and make your front end bounce like crazy.
'99 Toyota 4Runner LTD - Dual Locked | Geared | Mid-Travel | 35s | Armored
10-04-2012, 04:57 PM
Moderator
Real Name: Dylan
Moderator
Real Name: Dylan
Check to see if the upper ball joint is hitting the coil spring
The Rock Turtle Lifted, Locked, Boosted, Armored, TacoBoxed, and awaiting destruction.
10-04-2012, 05:55 PM
Real Name: Evan
Real Name: Evan
Yeah it's not all the time, just occasionally. And usually when it does it I've got the wheel just slightly turned. But then I'll hit a bump in the road and no sound whatsoever.?
This is reminiscent of my LBJ failure earlier this year. Very similar symptoms. More of a creaking or squeaking sound. Have you had the LBJ's replaced?
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
02-07-2024, 08:38 AM
Passenger side rear ting
I'm having something similar. I have a tinging / pinging sound from the passenger rear . Last July I replaced the coil springs, and shocks. The sound appeared in the last 2 months. It happens when I go over the lip into the garage as well as other times. I can also reproduce somewhat by rocking the vehicle back and forth. Been thinking of buying the chassis ears to track it down. I looked under there several times and cannot see anything that looks like it is causing the sound.
