Old 07-16-2023, 04:48 PM #31
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Originally Posted by 19963.4lsr5 View Post
When I put my rebuilt short block in my 97 I tried everything under the sun to prelube it before I tried starting it. But my starter wouldn’t turn over the engine fast enough to make the low oil pressure light go out. I even pulled the oil filter and pressureized the engine with compressed air to make sure the oil pump was primed.
End result is after much worrying I just let it fire up and 1/2 second after the new engine lit off the oil light went out.
I was so worried about wiping the cam bearings…….
Yes I can understand that. It's always sweating it until you hear it run and listen for a min or so..
My uncle always Said get that stp think stuff. Coat the cam bearings and lubes good so when it fires up it's not a dry start.
I really think as long as you coat everything with oil good. It will be fine.
Old 07-21-2023, 03:21 PM #32
Speedy's Avatar
Speedy Speedy is offline
Speedy is a jewel in the rough Speedy is a jewel in the rough Speedy is a jewel in the rough Speedy is a jewel in the rough
Speedy's Avatar
Anyone else think Al from Yota1 sounded like Jeff Bridges lol.
I heard him say "detonation cracks" and the subject vehicle has a supercharger. Does it also have a 7th injector, piggyback ECU for timing control, or other supporting modifications? I'm curious what was causing the detonation that cracked the heads.
Speedy is offline   Reply With QuoteReply With Quote
Old 07-21-2023, 09:15 PM #33
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I was wondering, too, if the super charger had any effect on the life of those heads. Yota1 probably would have a working theory being as many heads as they have seen...
Old 06-16-2024, 06:17 PM #34
AntonioCm1983's Avatar
AntonioCm1983 AntonioCm1983 is offline
Real Name: Antonio Claudio Michael
AntonioCm1983 is on a distinguished road
Very Thorough Series Timmy Did
AntonioCm1983 is offline   Reply With QuoteReply With Quote
Old 06-19-2024, 02:27 PM #35
Jose Rizal Jose Rizal is offline
Jose Rizal is on a distinguished road
Currently doing this job with the help of this video.
Thank you!
Jose Rizal is offline   Reply With QuoteReply With Quote
Old 06-21-2024, 09:16 PM #36
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Thank you!
You're welcome. I hope it goes smooth for you.
Old 06-25-2024, 01:45 AM #37
BigVulture1 BigVulture1 is offline
BigVulture1 is on a distinguished road
Thumbs down My HG blown twice in a year
I have a 96 Toyota 4Runner SR5 V6 5VZE engine RWD and the HG blew out on it. So I bought a used engine that was sitting for 2 years. Before installing the used engine I put a new water pump, timing belt assembly, O rings, hoses, spark plugs, wires, coils, serviced the injectors, and even put a new radiator and rear axles. No more than 10 days go by and the negative ground pins in the ECM that controls the injectors burnt out so I put a new ECM. Here I am 9 days later and after all the new parts and engine swap the damn HG blew out again. I totally at a loss, depressed, and pissed off all at once. Can you help me make it make sense as to how the head gasket can blow out on 2 different engines, in less than 6 months with no indicator lights warning me of a malfunction. My truck never overheated to cause a hg blow out. I kept up on the servicing scheduled maintenance. Please help me before I overreact and smash my mechanic.
I know buying a used engine has risks which is why I put all the new parts before installing. But I had 2 top knotch guys give the used engine a thorough inspection prior to installing and both gave me the thumbs up. I apologize if this isn't where I should post this. But I don't know what I'm doing
BigVulture1 is offline   Reply With QuoteReply With Quote
Old 06-25-2024, 10:50 AM #38
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
There's too many variables for me to give you an answer. I wasn't looking over the shoulder of the mechanic doing the job. A lot can go wrong if the mechanic doesn't know what they are doing, they do sloppy work, or they use inferior parts, like the head gasket. If they used an MLS (Multi-layer steel) gaskets, they checked the block surface carefully to make sure it met the minimum spec for flatness, they inspected the heads for cracks and pressure tested them, and they installed the head properly with new head bolts, you shouldn't be having a problem.
Old 06-25-2024, 06:25 PM #39
No I did a full engine swap after the first blown HG and used nothing but OEM parts to replace since the engine I bought was used. And less than ten days into having the replacement engine in the HG blew out on the new engine so I'm thinking if there's a faulty component with the 3rd gen t4r and it's causing the HG to malfunction
Old 06-26-2024, 03:32 PM #40
Early 5VZ's had head gasket issues (including recalls where Toyota replaced head gaskets). Lack of maintenance (coolant service) also will ruin head gaskets, especially over 25+ years. Later engines (say '98+ or so) with decent maintenance histories have near perfect head gaskets - but nothing is bullet proof.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 07-04-2024, 11:22 AM #41
I’ve done three sets of heads over the years and used YotaShop’s head replacement kit for all of them.
One important thing I learned over the years of wrenching is running a tap through the head bolt threads in the block to ensure the torque is correct.
Old 07-04-2024, 11:07 PM #42
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
The answer is the engine you got was a piece of crap. This is the risk you take buying used, even JDM that people profess is a great way to go. Any used engine you have no idea of its history is a crap shoot. The head gasket didn't blow 10 days after the install, the engine was already f*cked when you installed it.
Old 07-05-2024, 11:53 AM #43
BigKat BigKat is offline
BigKat is on a distinguished road
New Member - Stumped
PART 7
New member here. Wont let me post so i had to reapond to this thread...Great site and have learned much and appreciate all of the information here. I have a very unique situation going on. 2002 T4R - 5vz - runs great, but losing coolant from reservoir. Has new radiator, water pump, thermostat, rad cap, oil cooler hoses, valve cover gasket, hoses, belts. No visible leaks anywhere. Losing about a qt per 50 miles. Cooling system pressure test - holds 15lbs for 30 mins no drop. Cold compression across all cylinders 210lbs+ except cly 5 at about 170. Leakdown test on cyl 5 is horrid. Losing about 75% through cyl 1 & 2 with cyl 5 at TDC. Very slight loss through intake. Retested multiple times to make sure #5 was on compression stroke. Any ideas? Can't put the coolant loss together with these results.
BigKat is offline   Reply With QuoteReply With Quote
Old 07-07-2024, 01:26 PM #44
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Do a leak down test on Cylinder #5 again, but this time do it in conjunction with your cooling system pressure tester holding pressure on the cooling system. When you pressurize the cylinder, if the cooling system pressure tester gauge rises, you either have a cracked head or a head gasket issue. You can also leave pressure on the cooling system for longer than 30 minutes. Leave it overnight and use a borescope to look into cylinder 5 to see if coolant has pooled on top of the piston. I'm suspecting you have a cracked head. It's fairly common on these engine. Coolant doesn't just disappear like you're experiencing. if you haven't detected a leak anywhere, your engine has to be consuming it. Even if the leak was in the valley between the heads, the level would eventually spill out the backside of the engine and leave a puddle under your rig.
This video will show you exactly what I'm talking about. Good luck!
Old 07-08-2024, 11:24 PM #45
Will give this a shot. Thank you!
engine , head , heads , series , suspected
V6 engine replacement vs head gasket repair ??? zguy1 4th Gen T4Rs 142 09-14-2023 05:05 PM
Head Gasket or Cracked Head 02 4runner - Colorado any mechanics out there? vanderwiel 3rd gen T4Rs 9 09-26-2021 09:10 PM
Could this be a cracked head or gasket issue? (UV dye pic) Cycleandsurf 3rd gen T4Rs 3 02-07-2021 06:02 PM
head gasket repair leads to piston through head theresa4586 3rd gen T4Rs 37 03-20-2013 01:20 AM
blown head gasket, then warped head, now new engine straightjacket 4th Gen T4Rs 42 05-12-2012 09:45 PM
