Old 06-10-2023, 05:42 PM #1
MN4runnerman's Avatar
MN4runnerman MN4runnerman is offline
Real Name: Samuel
MN4runnerman will become famous soon enough
Real Name: Samuel
Blinker Issue
I know I know there lots of posts and I read all of those before posting this. What I have is a 1999 4runner SR5 4WD. What the problem is. Iím having the same issue other people have had. No blinkers but the hazards work just fine. And what Iíve done to rectify this is Iíve checked the fuse(good), Iíve replaced the hazard switch with new oem, and Iíve replaced the turn signal switch with a used oem one I had that worked in the old truck. Iíve even replaced the flasher. None have rectified the issue. I do have aftermarket led blinkers in my steel bumper. I do have an aftermarket T connector trailer hitch wiring too(this I have not tested yet). This truck has sat for the better part of 3 years now. Iíve done a lot of cleaning and havenít found any rodents that may have moved in and try to eat my wiring so I donít think itís that. Any ideas? Thanks
2001 Sport Edition 4WD, IJM, Auto, DD
1999 SR5 4WD, Millennium Silver Metallic, 5 speed, E-locker, Trail Rig
1998 SR5 4WD Custom bodywork from hitting a median. Beater truck.
1999 Limited 4WD No longer a vehicle. Now it's in parts and stored away.
MN4runnerman is offline   Reply With QuoteReply With Quote
Old 06-10-2023, 07:26 PM #2
RodrickHeffley's Avatar
RodrickHeffley RodrickHeffley is offline
RodrickHeffley has a spectacular aura about RodrickHeffley has a spectacular aura about
I would suspect the trailer wiring first, they seem to go bad almost on their own
1998 4Runner Limited 4WD w/Rear Locker
281k Miles
Build Thread
RodrickHeffley is offline   Reply With QuoteReply With Quote
Old 06-10-2023, 09:21 PM #3
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
My flowchart....
Does all the lights and turns and stop lights all function properly without the trailer hooked into it?
Does it function properly with trailer plug-in?
Mostly, if good without any plugged in, it's the trailer or damaged controller.
If messed up only in the trailer, in its the trailer or a damaged controller.
The trailer controller adapters can burn up and fail. I went through 2 on just a few years. Hopkins seem to better with led lights on the trailer.
Old 06-10-2023, 09:30 PM #4
Real Name: Samuel
Real Name: Samuel
Originally Posted by brillo_76 View Post
My flowchart....
I have not hooked up a trailer to the truck yet to test that specifically. I just drove it from storage and noticed the turn signals do not work. The flashers do work when pressing the button but thatís it.
Old 06-13-2023, 10:19 AM #5
Real Name: Samuel
Real Name: Samuel
Just an update. It wasn't any of these issues and I feel kinda dumb. After I got my truck out of storage I took it over to a shop to have a new Elocker actuator and wiring harness installed since my original harness was damaged. The tech doing the install put a tap-a-fuse, for the new harness, in the interior fuse box and while in the process of doing that he moved the fuses in a way that they were now 1 spot higher than what they should be based on the diagram on the cover. When I initially looked I pulled the 10amp turn signal fuse and it looked good and put it back where I found it. Then proceeded to try literally everything else because I was under the impression the fuse was good. So moral of the story is to pay attention to everything. This morning I put the fuses back in their correct spots and everything works.
blinkers , issue , iíve , replaced , switch
My blinker mod Wildcat Classic T4Rs 7 02-05-2013 09:50 PM
blinker mod Toyota4Runner4WD 3rd gen T4Rs 28 03-10-2012 08:51 PM
frick , simple help needed asap, blinker/saftey issue theizzardking 3rd gen T4Rs 5 11-02-2010 06:59 PM
4Runner: LED Blinker moved to Aux, Driving light installed in Blinker spot KU_MechE 3rd gen T4Rs 0 09-24-2006 05:31 AM
