Real Name: Patrick
Real Name: Patrick
The Schematic I have is marked as being for a 2001-2005 4Runner, and the way Toyota changes wire colors they can change from month to month, it seems like, so the colors I found were different than the ones you specced. By the same token, the wires fade over time, and can fool you in dim light, which could account for the differences. Anywho, The way I read it, 1,2, and 3 feed from the sensors in the tank, the level sensor in particular, and feed back to the "Combination Meter", or the gauge cluster. The fuel gauge in particular, and IF the sensor goes low enough, you get the light. I THINK, although very rarely, that pin 3 is the voltage source, and 1 and 2 feed back to the gauge set to run the meter.
Does that help any?
Pat☺
