Old 06-16-2023, 04:53 AM #1
henrytmoc's Avatar
henrytmoc henrytmoc is offline
Real Name: Hen
henrytmoc is on a distinguished road
henrytmoc's Avatar
Real Name: Hen
Random Misfiring on Second Startup after 30min
Hi All,
Been lurking these forums since I bought my 4Runner in January. I've come across some misfire issues and have yet to find a remedy.
The vehicle is a 2000 4R Limited with 4WD and Rear Locker.
On initial cold start, it runs great, no issues whatsoever, no codes, no lights, no indication of any problem.
The problem however arises when I drive it and park it for let's say 20-30 mins. I would start it again and would get shaking after about a minute. When this happens, it seems to go into limp mode and I cannot go past 1500rpm. Sometimes I'll get a code (P0300, P0301, P0303, P0305, P0306). Most times, it'll just show a pending code. If I give it a couple revs, it'll usually fix it and it'll drive just fine again or if I turn it off and start it back up, it's fine. If I drive it and park it overnight and start it again, I have zero issues. Seems to happen only after it sits for 30-45 min and I drive it again.
Here is all that I have replaced with new OEM Toyota parts: TPS, MAF, spark plugs, crank position sensor, and air filter.
My mechanic, as well as another friend who ran into a similar issue, but only on cold start told me that it may be early signs of a failing head gasket. Sounded like coolant may have been seeping into the cylinder and causing the shaking until the excess coolant was burned off. At this point, I had run out of options. I went ahead and did the head gasket as well as other misc things that needed to get done anyways. Head gasket work was done along with a new knock sensor harness since mine was old and brittle, spark plug wires, coil packs (only OEM Denso).
However...$3k later with all these new parts, machining the heads, reseating the valves with new seals, new OEM injectors, and a new fuel filter...I'm still running into the same misfiring issues. It's also worth noting that the engine was replaced at some point as the VIN plate was from a different 4runner.
Any ideas what it could be? There was an issue with the throttle body sticking. If the throttle body is forced closed, the motor will begin to shake like it's misfiring. I also don't know if the fuel pump was ever changed, so I'm not sure if maybe the motor is bogging from a failing pump not supplying enough fuel to the injectors. The other concern was that because of how old the car is, the harness for the fuel injectors may be brittle so we may need to finagle with it. Aside from those 3 things...I am completely lost. Any help would be greatly appreciated.
henrytmoc is offline   Reply With QuoteReply With Quote
Old 06-16-2023, 05:02 PM #2
spartacus's Avatar
spartacus's Avatar
Might be time 'for motor west injectors.
Old 06-18-2023, 01:24 AM #3
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
Could be an injector as they are a common problem after a few decades, and possibly wiring, or missing teeth on the crank sensor trigger ring, not sure if a bad cam sensor would cause this?
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 06-21-2023, 07:36 AM #4
jkoni426 jkoni426 is offline
Real Name: Joe
jkoni426 is on a distinguished road
Real Name: Joe
Like the others said when mine had those symptoms it was a bad fuel injector on cylinder 3 (P0303).
'99 T4R SR5 V6 4WD Imperial Jade Mica | 199mm TBU
jkoni426 is offline   Reply With QuoteReply With Quote
Old 09-24-2023, 06:31 AM #5
DD4Runner DD4Runner is offline
DD4Runner is on a distinguished road
Thumbs down
I have a similar issue.
Replaced all plugs, coils, and injectors.
Smoke test shows no vacuum leaks.
Every part I replace makes it worse.
DD4Runner is offline   Reply With QuoteReply With Quote
Old 09-24-2023, 01:40 PM #6
Romeo1's Avatar
Romeo1 Romeo1 is offline
Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice
Romeo1's Avatar
Chasing ghosts is always a good time.
I'm assuming the spark plug wires were replaced. Are they routed properly? There is a specific order in where to cross them.
Has actual spark been verified?
Next, is even though you have a new head gasket and all, what are the compression test numbers for all the cylinders?
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
Romeo1 is offline   Reply With QuoteReply With Quote
Old 09-25-2023, 10:04 PM #7
cthomsen99 cthomsen99 is offline
cthomsen99 is on a distinguished road
Sorry to hijack this thread but I'm having similar issues. Recently purchased 1999 Limited with 271K miles. Started having rough idling and got codes P0300, P0304, and P0305. With unknown prior maintaince, I put in new denso plugs and wires and did a seafoam spray treatment. Runs great when cold but has issues upon warm restart. Compression test shows 170-180psi in all cylinders. Would new injectors be the next logical step? Thank you for any suggestions.
cthomsen99 is offline   Reply With QuoteReply With Quote
Old 09-26-2023, 10:05 AM #8
spartacus's Avatar
spartacus's Avatar
It is likely they get heat soaked and stop functioning. The injectors should be 13.8 ohms give or take a couple when cold. Replace them if they Re out of spec.
Old 09-26-2023, 11:52 AM #9
Thank you. I'll get some injectors ordered and installed.
Old 09-26-2023, 01:55 PM #10
gamefreakgc's Avatar
Real Name: Jerod
gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of
Real Name: Jerod
Misfire codes are either a fuel, air or spark issue. You've handled the spark maintenance items. The other issue could be air that isn't metered correctly. Try cleaning off the MAF with loads of MAF cleaner/carb cleaner and see if that helps the stumble and misfire. Also change your air filter 1x per year.
The last would be fuel delivery which is controlled by the front O2 sensor and our friend once again, the MAF sensor. It could also be the injectors but if you haven't ordered them already, put 1-2 bottles of high quality injector cleaner such as Lucas, Royal Purple, AMSOIL. Avoid bargain brand stuff. If there's any improvement, even slight improvement, it may be the injectors causing the misfire. Instead of replacing them, send them off to an injector cleaning service as it'll only cost about $125 for the service + shipping. You might even find a local place like I did and have no shipping costs.
326WHP 347TQ
Old 09-26-2023, 03:08 PM #11
Should have mentioned that I've cleaned the MAF sensor and run injector cleaner through it with no improvement. Air filter is good. I'll most likely order injectors from Motorwest as mine have 270K+ miles on them. No local shops in my very rural area. Thank you.
Old 09-29-2023, 12:43 AM #12
The current codes are: P0300, P0303, P0302, P0171. No codes for any failed sensors, like O2, MAF, etc.
I have a hard time with this because the 220k service encompassed so many parts... how can I possibly know what was disturbed during the maintenance?
All new wires along with the other parts. I can't see how it's possible to route the wires any way other than one.
Why would compression be an indicator when cold running is perfect? Outside of this suggestion, I've tried everything I've read and been told on these forums with no luck, and I just can't keep trying stuff with no understanding of the logic.
I've also tried the local "Toyota Specialists" - at $900 for an injector cleaning and one replacement. No improvement though, just a suggestion to replace my brakes and suspension, and a suspicious vacuum line plugged with a rubber cap? Thanks.
Is the factory manual is an accurate troubleshooting guide?
Or, is taking it to my nearest Toyota dealer a sure-fire solution? I'm at the end of my patience for solving this puzzle. If I don't find an answer soon, I will incinerate the truck and the haunted demons that possess it and accept that 4Runners just aren't as reliable as 'they say'.
Old 09-29-2023, 12:46 AM #13
Wouldn't the ECU throw codes if the O2 or MAF sensors were dirty/bad?
Old 09-29-2023, 08:07 AM #14
The other factor for a hot restart issue is a bad head gasket.
Old 10-29-2023, 03:03 PM #15
Finally had time to replace the injectors yesterday. Runs great now and no more codes after the first couple of drives.
drive , fuel , issues , misfiring , start
94 SR5 V6 4x4 starts heating up after driving for 20-30min marcusSRG Classic T4Rs 12 07-31-2018 05:40 PM
:( misfiring, need help Mtssurf1 3rd gen T4Rs 0 03-15-2014 01:29 PM
Misfiring with no codes browningcrew24 3rd gen T4Rs 8 08-02-2013 12:15 PM
Misfiring on 3 cylinders FoneRunner 3rd gen T4Rs 9 05-02-2011 01:38 PM
Misfiring but don't know why dolezal83 Classic T4Rs 5 01-14-2009 10:26 PM
