06-26-2023, 03:21 PM
Will Tacoma/Tundra wheels fit my 2002?
Need new tires and there’s quite a few stock wheel/tire combos on marketplace for a great price. Assuming the lug is the same, should stock wheels from the newer vehicle fit?
06-26-2023, 03:36 PM
depends which year and style, the 2nd gen taco rims do not fit well as the offset is incorrect pushing the rim inboard for a less than desirable look, not sure about the older tundra offset, but obviously the new tundra 5 bolt won't work. best fit is the 2014-15+? factory trail edition 17" rims imo.
06-26-2023, 04:08 PM
What about these? Say they’re off a 2020 Tacoma.
[IMG]//https://i.imgur.com/VCQ8wua.jpg[/IMG]
06-27-2023, 01:01 PM
Also found these, off a Sequoia. Would they fit?
Imgur: The magic of the Internet
06-27-2023, 01:15 PM
Both of those will fit. The Tacoma ones will push the wheels inward. The Sequoia wheels are the same as some of the first gen Tundra wheels - sometimes with just a different color paint.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
06-27-2023, 01:28 PM
Thanks. Those tires on the Sequoia wheels are 275/65/r17, those will fit? Those Falken tires have great reviews. He’d take 450 for the set of 5, good deal?
06-27-2023, 01:36 PM
Yeah, if that really is the size (265-70/17 is more normal, as is 265-65/17). Also a good deal if they are in good shape.
06-27-2023, 04:42 PM
What about these? They are off another 4Runner. Those Toyos seem to have some good life left, and they would take 350. 265/65/r16
06-27-2023, 09:25 PM
Yeah you’re right, they are 265-65/17. I might pull the trigger, that tire seems to be pretty popular.
06-28-2023, 01:31 PM
Literally ANY 4Runner wheel will fit the lugs/hubs. You'll want 3rd gen+ wheels (96 and newer) to fit over the brakes.
06-28-2023, 05:52 PM
Thanks again for the reply. Based on input from friends I’m going to go with these that are coming off a Sequoia. The Falken tires have awesome reviews and they look like they have a lot of life left from the pictures.
