Old 07-31-2023, 09:13 PM #16
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
Good mod! Note that this will only work if you have an open or selectable diff in the front. Otherwise you’ll be running 3WD.
Having manual hubs I agree that 2LO is very handy. Especially with a manual! I use it in driveways and drivethrus often
JZiggy is offline   Reply With QuoteReply With Quote
Old 08-01-2023, 02:08 PM #17
Robb235's Avatar
Robb235 Robb235 is offline
Real Name: Robert
Robb235 is on a distinguished road
Robb235's Avatar
Real Name: Robert
Originally Posted by Cree View Post
Sounds like it's time to put that fuse on a toggle switch.
On my list of things to do, but got several other projects ahead of it. Like replacing the steering rack, and rebuilding the jet pumps on my boat.
1999 Toyota 4Runner Limited 4x4 - 231mm Tundra Brakes - B&M 70264 Transmission Cooler - Monitoring ATF Temps and AFRs With My iPhone - DIY Projector Headlight Retrofit - Cooper Discoverer AT3 - OME 906 Coils & Rancho 9000XL Shocks (Rear) - Airlift 1000 - RadioShack $5 Rear O2 Simulator
2000 Yamaha XR1800 Jet Boat - MR1 4-Stroke Engine Swap
Robb235 is offline   Reply With QuoteReply With Quote
Old 08-02-2023, 11:42 AM #18
Rushthezeppelin Rushthezeppelin is offline
Rushthezeppelin has a spectacular aura about Rushthezeppelin has a spectacular aura about Rushthezeppelin has a spectacular aura about
It's not 3wd if you have ADD. With ADD disconnected it will just spin the carrier and the disconnected shaft. And not transfer power to the driver tire.
'98 SR5 5 Speed
Rushthezeppelin is offline   Reply With QuoteReply With Quote
Old 08-02-2023, 03:49 PM #19
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
You and JZiggy just said the same thing in different ways. JZiggy's point was that this method doesn't work if you have a traction device in the front diff. I almost said the same thing as you, but reread what he said before posting.
2low , iím , low , side , t-case
Changin out a multimode 4wd t-case Dara 3rd gen T4Rs 8 01-23-2021 10:46 PM
FS: 3rd gen multimode transfer case set up. T case, Ecu, COLORADO Tinigunner11 For Sale: T4R Items 0 03-03-2019 07:56 PM
Can some multimode case guys check something for me? puppetz007 3rd gen T4Rs 13 01-08-2019 03:34 PM
FS: 99 multimode transfer case / north AL / $100 68ChargerJMP For Sale: T4R Items 2 09-27-2017 11:13 AM
Crawler and multimode t-case MandAtaco 3rd gen T4Rs 2 01-24-2015 12:19 PM
