Old 07-08-2023, 09:46 AM #1
Drugolf Drugolf is offline
Drugolf is on a distinguished road
Winch Control Box Location
I recently installed an Addicted Offroad Plate bumper on my 2000 limited. I am now looking at installing a winch. As with most of these bumpers and winches you run out of room for the control box to attach directly to the winch. I am not going to cut my grill if at all possible.
Any recommendations or ideas on where it should go?
Drugolf is offline   Reply With QuoteReply With Quote
Old 07-08-2023, 10:28 AM #2
T4topher's Avatar
T4topher T4topher is offline
T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light
T4topher's Avatar
I moiunted my control box in the passenger wing of the bumper. Kind of tight but I didn’t have to extend the wires to the control box. My buddy has his mounted where the cruise control goes.
T4Tophers build (click here)
T4topher is offline   Reply With QuoteReply With Quote
Old 07-09-2023, 10:24 AM #3
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
I mounted mine inside engine bay RH side, mounted controller plug recepticle in grille.
Depending on winch clutch lever location you will need to clock it, cutting grille cross bar is necessary.
AOR bumper & 96-98 grille works without cutting grille.
Winch Control Box Location-winch-jpg
Old 07-10-2023, 06:30 PM #4
Okay, thanks. I was wondering about having to cut the grille. Based on my measurements, there is no way to get the winch in there w/o cutting the grille. I have the same grilles as yours shown.
Old 07-10-2023, 07:20 PM #5
prybar's Avatar
prybar prybar is offline
prybar is on a distinguished road
prybar's Avatar
Unmount the control box from the winch, and stick it off to the side where you have some space. That's what I did for my hidden winch mount under the stock bumper.
'99 Limited, 260k
prybar is offline   Reply With QuoteReply With Quote
Old 07-11-2023, 02:47 PM #6
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Old 07-11-2023, 04:29 PM #7
Sean K.'s Avatar
Sean K. Sean K. is offline
Sean K. is on a distinguished road
Sean K.'s Avatar
Mine's on the front of the core support, driver's side behind the grill mounted vertically. IIRC, I had to remove the overflow tank for the radiator to mount it there and then reinstalled the overflow.
Sean K. is offline   Reply With QuoteReply With Quote
Old 07-12-2023, 07:06 AM #8
Real Name: Mark
Real Name: Mark
You probably know, remove grille mount winch install grille
Amount you have to trim going to vary with winch used, Smitty one of smaller ones.
Mounting location high n dry is best, some went bumper wing, water crossings don't mix well with that.
Quality Copper Battery Cables Made in the USA! - BatteryCablesUSA Good place to purchase large guage cables.
Old 07-12-2023, 12:50 PM #9
I have an enclosed top plate bumper, so I was able to fit the control box behind the grill (some trimming on the back - the front is still original) bolted to the top of the bumper. Had to make/modify a couple brackets. I do have to pop the hood to attach the controller - but it keeps prying eyes/hands away from it the rest of the time.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 07-13-2023, 02:05 AM #10
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
I extended the wires on my Warn contact box and mounted it to the firewall driverside by the wheel-well, and ran the controller inside the cab, this way I can run it from inside the cab and reach the winch to spool out with controller in hand. The contact box stays high and dry aswell in this location and controller is always connected.
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 07-14-2023, 01:32 PM #11
Daryl Elmore Daryl Elmore is offline
Daryl Elmore is on a distinguished road
I mounted my Badlands controller behind the grill using a bracket I made mounted to the center support in front of the radiator.
Daryl Elmore is offline   Reply With QuoteReply With Quote
attach , box , control , cut , winch
Panic Alarm Control Module: Location? USA591 4th Gen T4Rs 8 08-29-2023 11:42 AM
2001 ABS Control Unit Location 954RUNDEN 3rd gen T4Rs 4 02-23-2020 07:40 PM
4x Innovations front plate bumper winch mount/controller location OutdoorLF 3rd gen T4Rs 5 06-28-2015 09:14 PM
mounting winch control box on ARB PRADO in empty "W" location? cordrayj1 3rd gen T4Rs 0 12-13-2010 12:05 PM
Alarm control box location and Frequency jmholley 3rd gen T4Rs 0 08-25-2010 11:53 AM
