Old 07-16-2023, 04:28 PM #1
RumHam26 RumHam26 is offline
RumHam26 is on a distinguished road
Can I bleed front brakes only?
Just replaced calipers on my 2001. Can I bleed only the fronts, or do I have to do all four? I've seen some mention that front and back are separated somehow, but can't find confirmation of this. I lost minimal brake fluid in the caliper swap.
Thanks!
RumHam26 is offline   Reply With QuoteReply With Quote
Old 07-16-2023, 04:41 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Thanks!
You can bleed only the fronts if you want till hopefully you didn't run the master cylinder dry.
If you did that you have to bench bleed the master cylinder then bleed all 4. Along with activating the abs to make sure no air is in it too..
Old 07-16-2023, 10:38 PM #3
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
You can do fronts only. That's what I did a few months ago. No issues. Don't let the master go dry whatever you do, like brillo said.
Sent from my SM-S908U using Tapatalk
Old 07-17-2023, 10:07 PM #4
gamefreakgc's Avatar
Real Name: Jerod
gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of
Real Name: Jerod
Each brake has its own line coming from the ABS module so you could do just one if you had to. No need to do all 4 unless you have reason to do so.
326WHP 347TQ
Old 07-18-2023, 03:54 PM #5
phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future
As long as there are no bubbles in the ABS system, rear brake lines/cylinders or master cylinder, you can do fronts only. If there is air in any of those other locations, you must to rears first.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 07-21-2023, 06:03 PM #6
Clickx Clickx is offline
Clickx is on a distinguished road
Fr,fl,rr,rl
Clickx is offline   Reply With QuoteReply With Quote
Old 07-21-2023, 06:47 PM #7
Originally Posted by Clickx View Post
Fr,fl,rr,rl
Absolutely not, at least on the '96-'00 models, from the FSM:
Old 07-21-2023, 09:00 PM #8
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
The 01 and 02 have a brake line going to each wheel. Thus a line to each wheel. The 96 thru 2000 only have 1 line for the rear.
01 and 02 have a different master cylinder as well as abs system too.
Old 07-24-2023, 03:37 PM #9
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Fr,fl,rr,rl
You always bleed from the furthest corner from the master cylinder to the closest so what you posted is incorrect.
Old 07-26-2023, 06:04 AM #10
enginelover enginelover is offline
enginelover is on a distinguished road
Sometimes I get the BLUE brake fluid (yes, I know the DOT specifications are for amber) which helps me know exactly when the new fluid is starting to come out.
enginelover is offline   Reply With QuoteReply With Quote
Old 07-26-2023, 02:06 PM #11
Man, I wish it was easy to get Super Blue these days.
bleed , find , front , separated , swap
Can I bleed only the rear brakes? RumHam26 3rd gen T4Rs 3 10-25-2019 12:40 AM
How to bleed brakes 24poepoe 5th gen T4Rs 28 04-15-2019 09:49 AM
bleed brakes? Kev4runner Classic T4Rs 6 10-08-2012 01:09 PM
What to do not to bleed brakes? Dang1 4th Gen T4Rs 2 10-27-2011 12:36 PM
power bleed or vacuum bleed brakes schan1w Maintenance/Detailing 4 08-13-2007 07:19 PM
