Old 07-17-2023, 10:38 PM #1
Pyral's Avatar
Pyral Pyral is offline
Real Name: N/A
Pyral has a spectacular aura about Pyral has a spectacular aura about
Pyral's Avatar
Real Name: N/A
Side to side clutch adjustment
My clutch pedal is misaligned so that it rubs against it's own mounting bracket. I can't find any instruction on how to make these adjustments, all the threads are on clutch free play.
Does anyone have experience with this?
Here are some photos to explain what is happening.
1998 4runner 2.7 manual
Pyral is offline   Reply With QuoteReply With Quote
Old 07-22-2023, 08:49 AM #2
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
Bump
Bump
Bump
Old 07-22-2023, 10:05 AM #3
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I do not. All my pedals ever did was squeak.
Old 07-22-2023, 11:40 AM #4
HiLife HiLife is offline
I have not experienced with having an alignment issue in that area too, my setup is still original.
Have you informed Toyota Corporate about this issue?
55107-35050 supersedes original part# 55107-04020.
As Toyota dwindles down part numbers from older vehicles, they try to find the best replacement part number that should work in that application. And if there is a misfit, I'm sure Toyota want to know about it. Or could be that Toyota knows about fitment issues already, and still, that's the closest part that "kinda" works is the best Toyota can do.
I don't think there an Toyota approved adjustment for your issue.
I could be very well in that same boat as your in too. I have new Toyota parts to rebuild my clutch area when my old setup lets go.
Old 07-22-2023, 09:43 PM #5
gamefreakgc's Avatar
Real Name: Jerod
gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of
Real Name: Jerod
That clutch bracket has been replaced by someone at some point. Was it a 5-speed swap? It may not be the correct part.
326WHP 347TQ
Old 07-23-2023, 08:44 PM #6
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
Nope, my 4runner was always a manual. It was replaced (probably under my ownership) because when I bought it the clutch pedal spring had worn through the bushing and into the bracket itself. I say probably because I didn't do the installation myself, and my early maintenance records that would say are at my parents house.
Someone will ask, this vehicle wasn't involved in any serious crashes. It was in a "minor collision" in 9/2001, I'm guessing it was rear ended from the dented hatch. The frame and body are straight, I'd of seen signs with all the work I've done if it had been more serious.
I haven't informed Toyota. Should I? I have a feeling they'd either question the installation of the bracket, or the master cylinder, since neither was done by them.
Could an improper installation of the bracket cause this? What should I do?
Old 07-24-2023, 04:38 AM #7
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
Cheap Aisin replacement? I'm not a 5-speed owner so I can't really say, but that's my best offer. Recently purchased an Aisin replacement for my Dad's Tacoma and he's loving it, no issues.
Sent from my SM-S908U using Tapatalk
Old 07-24-2023, 06:38 AM #8
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
Maybe the pedal bushings are totally worn out?
JZiggy is offline   Reply With QuoteReply With Quote
Old 07-24-2023, 09:08 AM #9
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I am suspecting what jziggy is saying. Must likely your bushing are gone.
Old 07-24-2023, 09:09 AM #10
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Good to know Asin sales a replacement.
Old 07-24-2023, 11:15 AM #11
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
I got my master cylinder at the dealership. The old one was the original. Both scrape in the same place.
The aisin ones are identical, because even one I got from the dealership says Aisin. Oem/Aisin is interchangeable in this instance. Toyota uses Aisin as a supplier.
Pedal bushings sounds possible. I’ll have to check them.
Old 07-24-2023, 12:22 PM #12
JZiggy's Avatar
JZiggy's Avatar
For reference in case it helps. There's also a little bushing for the pivot pin.
https://www.toyota-4runner.org/3765427-post618.html
Old 07-25-2023, 09:22 PM #13
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
I was digging through my glove box and I found some old records. One of which had an interesting line item: new clutch spring and replacement bushings.
This is when my 4runner was still new, so this is further evidence of how poorly designed the clutch pedal mechanism was. 2005 was still a long time ago, but my clutch pedal has been an issue for at least 3 of 4 owners.
This owner from my knowledge would sell my 4runner during the 3rd gas crisis of 08.
Old 07-25-2023, 10:27 PM #14
JZiggy's Avatar
JZiggy's Avatar
I had a similar thing with mine. The PO did everything at the dealer he bought it from. The clutch pedal would squeak and the dealer replaced the whole pedal mechanism 2 or 3 times.
The problem was the torsion spring and the bushings that go on that spring. My first project was to delete that spring and use the linear return spring.
Does your truck still have the torsion spring?
Old 07-26-2023, 05:59 AM #15
enginelover enginelover is offline
enginelover is on a distinguished road
I echo that sentiment that the funky double-twisted U-shaped torsion spring should be junked for a normal in-line double-twisted brake-pedal spring instead.
Worked for me - years ago - and the squeak has never returned even as the clutch pedal returns just fine all these years.
enginelover is offline   Reply With QuoteReply With Quote
clutch , free , play , side , threads
2010 attempting the Rav4 side mirror w/ blind side bubble mod WhiteRunner10 5th gen T4Rs 1 03-18-2019 10:00 PM
Clunking sound with light side to side movement after in rear after 3" lift BXPhoto 3rd gen T4Rs 1 11-24-2016 11:53 PM
Wanted: Drivers side black rear side plastic bumper Griswald Want to Buy/Trade 0 08-31-2015 02:05 PM
Rear End adjustment side to side? SweetWaterSurprise 3rd gen T4Rs 33 11-28-2013 08:04 PM
