Old 07-22-2023, 10:42 AM #1
FudgeYes FudgeYes is offline
FudgeYes is on a distinguished road
Worth doing head gasket again?
Hello forum.
Due to some kind of blockage in my cooling system, my truck overheated unexpectedly.
It was fine for a while,then on a sudden glance to my temp guage, I noticed a HUGE spike in temperature and immediately pulled over.
Head gasket was already blown by that point.
The issue is, this will be the SECOND time this engine has had a head gasket done, and I don't know how hot it got back then.
It also had its heads sent to a machine shop then.
I know that I got it to at least 250-260+ f since the needle was so high.
When starting it again it runs really well, like it did before the gasket blew.
Are these blocks known to warp?
Could I potentially just get the heads/block checked for flatness and go from there?
FudgeYes is offline   Reply With QuoteReply With Quote
Old 07-22-2023, 03:50 PM #2
How do you know the head gasket failed?
What caused it to overheat? The head gasket?
Old 07-22-2023, 09:27 PM #3
MaineRunna's Avatar
MaineRunna MaineRunna is offline
MaineRunna will become famous soon enough MaineRunna will become famous soon enough
MaineRunna's Avatar
How do you know the head gasket is blown? Did you do a hydrocarbon or compression test? These engines are pretty tough. What caused the overheat?
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
MaineRunna is offline   Reply With QuoteReply With Quote
Old 07-24-2023, 04:46 AM #4
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
I think it's safe to say that any block can warp at temperatures that high. I'm sure you can get the heads checked but it's going to require a tear down, which at that point, you might as well do the HG again or just throw new/used ones in the there.
What's leading you to believe that you blew the head gasket again? And why is this the second time it's happened now? Is there a deeper issue that's not being addressed with your engine?
Sent from my SM-S908U using Tapatalk
250-260+ , back , gasket , head , needle
Engine Head Gasket / Cracked Head Repair (Toyota 3.4L V6 5VZ-FE ) mtbtim 3rd gen T4Rs 32 07-21-2023 09:15 PM
Blow head gasket...need shop in Fort Worth area melt757 Texas & Oklahoma 1 05-31-2022 06:48 AM
Blown Head Gasket...worth repairing?? melt757 3rd gen T4Rs 18 04-23-2022 07:40 PM
Head Gasket or Cracked Head 02 4runner - Colorado any mechanics out there? vanderwiel 3rd gen T4Rs 9 09-26-2021 09:10 PM
2004 head gasket #6 (gasket treatments work?) ingrjc1 4th Gen T4Rs 7 12-01-2019 12:39 PM
