Old 07-23-2023, 10:20 PM #1
montana4runner montana4runner is offline
Real Name: Rick
montana4runner is on a distinguished road
Real Name: Rick
2000 Sport headlight woes
This problem has been plaguing me for about six months now, and I can't seem to figure it out. I have been extremely busy for the last six months or so, but finally have a little free time to devote to fixing this. It started with my trip od mileage being canceled every time I shut the vehicle off. Then i would end up with a dead battery occasionally. I have the auto-on headlight feature, and one evening came back out into the garage and noticed the headlights had come on. This has happened now, a number of times. I'd get in the habit of making sure the headlights were turned off each time I'd shut down the vehicle, get complacent, and eventually go back to my old habits. all would be good for a while, then, dead battery again. I will admit that I am a very poor electrician, but have been researching this for a while and haven't found anything that addresses this issue, I am fairly certain that the odometer resetting and this headlight issue are related. Also, I have been having an issue with the drivers side dome switch going funky now and then. Is it possibly as simple as perhaps a headlight relay? I don't want to start throwing parts at this, as we all know how spendy that can get.To preface, all grounds have been checked, at least the ones I am aware of. Any ideas as to where to start to look?
91 SR5- sold
2004 SR5- sold
2000 SR5 Sport
2011 Tundra CM
montana4runner is offline   Reply With QuoteReply With Quote
Old 07-27-2023, 01:43 PM #2
prybar's Avatar
prybar prybar is offline
prybar is on a distinguished road
prybar's Avatar
Bump
'99 Limited, 260k
prybar is offline   Reply With QuoteReply With Quote
Old 07-27-2023, 03:54 PM #3
Twisted Sid's Avatar
Twisted Sid Twisted Sid is offline
Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about
Seeing as how your having issues with the drivers side door switch, I'd start there. That switch is what controls the auto lights to turn off when you open the door. There isn't much to them so removing the switch and cleaning it with electric cleaner or even brake clean might make it work better. You could also try swapping the switch with one from the rear doors and see if that helps.
'99 4Runner SR5: 5VZ, 2wd, AT, 400k+ club
'94 Pickup: 2wd, 22RE, 5spd, (3RZ swap in progress)
Front: Total Chaos Uniball Kit, Fox 2.5 8'' coilover
Rear: Deaver F67 Leaf Springs, Fox 2.0 14'' Reservoir Shocks, E-locker Axle 4.88 Gears 33x10.5 BFG ATs
Twisted Sid is offline   Reply With QuoteReply With Quote
Old 07-28-2023, 12:00 AM #4
Real Name: Rick
Real Name: Rick
Thank you sir. I will start there.
91 SR5- sold
2004 SR5- sold
2000 SR5 Sport
2011 Tundra CM
Old 09-16-2023, 09:35 PM #5
Real Name: Rick
Real Name: Rick
Just an update, removed and cleaned up the door switch, and re-installed. Seemed to have fixed the trip odometers canceling out every time the vehicle was turned off. Also, have not had the headlights mysteriously come on while the 4Runner sits overnight or in the parking lot at work. Time will tell if this fix cured both problems, as I have gotten in the habit of ensuring that the headlights were turned off at the stalk, and honestly am a little gun shy to leave them on auto after so many dead battery occurrences. Will report back if there are any changes
91 SR5- sold
2004 SR5- sold
2000 SR5 Sport
2011 Tundra CM
battery , dead , headlight , issue , time
2000 Limited headlight stalk vs 2001 SR5 headlight stalk fblainen11 3rd gen T4Rs 15 09-22-2016 09:54 PM
WTB: Driver Side Headlight, 2000 SR5 Sport, Phoenix area MVP Want to Buy/Trade 1 10-14-2014 09:31 PM
2000 4runner headlight diagram hoe_nah 3rd gen T4Rs 25 01-11-2014 03:06 PM
2000 4Runner Dim Headlight/Bad Focus? dbsoundman 3rd gen T4Rs 2 11-24-2012 01:06 AM
2000 headlight problem Mwl4runner 3rd gen T4Rs 1 04-16-2012 11:44 PM
