Old 02-11-2024, 03:56 AM #31
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
Originally Posted by Endlessblockades View Post
Thanks for the info. My UltraGauge currently shows a max of about 14.23 with a stock Alt. Do you think it would be worthwhile to pop a fixed volt boost unit in to help out my new AGM battery? The variable unit is out of stock.
When I plug in make/model year this is the only unit they have in stock MK3 Mini blade 7.5A (Electronic fuse version) (Micro blade compatible) | HKB Electronics
It's not what your observed max voltage is, it's what voltage the car spends most of its time at.
The voltage is supposed to vary with the temperature sensed at the alternator (a proxy for the temperature at the battery), so I suggest observing how much of your driving is at what voltage. It always starts high, and then drops down as the engine compartment heats up. If you are putting in many minutes or hours at too low a voltage---It seems that what constitutes "too low" is not an exact science---boost the voltage. Try not to let it go above 14.9-15V for any substantial length of time. The fixed 0.6V boost unit would have worked for my 4Runner, but I didn't know that when I began the voltage adventure, so I figured I'd get the adjustable one. When I first decided to get one, the adjustable units were out of stock. Within a few weeks/months, they became available again. I consider the concept of doing this an experiment, although supposedly thousands of satisfied Aussies use these things on their utes and Land Cruisers.
YMMV-
Results not guaranteed-
Good luck with your "experiment"!
pluton is offline   Reply With QuoteReply With Quote
Old 02-11-2024, 12:56 PM #32
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
YMMV-
Understood. i drove about 300 miles yesterday and around 14.10 was what I saw most of the time. Wondering if throwing the battery on my NOCO genius charger every now and again is good enough to keep the battery happy.
Old 02-12-2024, 08:56 PM #33
Everything I've seen seems to show the ideal charge voltage for an AGM to be 0.1-0.4V higher than FLA. Toyota/Denso is generally pretty conservative with charging voltages (on the low side, I mean - compare to most US manufacturers), but things have been working just fine for the last 25 years for 3rd gens... why change it? The OEM charge voltage may not be as efficient at charging an AGM, but the float voltage will still be correct for battery health.
That said, an overnight on a trickle charger ever 1-3 months is a good idea. That's what I do on our vehicles, generally.
4Runner: 105A upgraded Denso, sits a week or two regularly but driven long drives when driven
Van: 150A factory alternator, but lots of short trips
Volt: 130A factory DC-DC converter, factory AGM 12V battery
Camry: Tiny Miata battery (U1R), always on the trickle unless being driven
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 02-14-2024, 11:31 AM #34
Real Name: Blair
Real Name: Blair
Update. I went ahead and ordered the fixed voltage booster. Due to the current exchange rate ( 1 AUD = 0.65 USD) it comes out to 49 USD landed (free shipping basically). I'm spending free money on this probably unneeded fuse, so don't @ me.
Subtotal: $50.00
Shipping: $22.00
Grand Total: $72.00 AUD
I'll post some before/after shots of the V readings if I see a change.
Old 02-15-2024, 02:31 PM #35
19963.4lsr5 19963.4lsr5 is online now
This is with the GM AC Clutch diode. If put in backwards the battery light comes on. I’m going to add the 7.5a fuse to it also.
19963.4lsr5 is online now   Reply With QuoteReply With Quote
4runner , battery , capacity , fit , hood
Battery voltage dropping randomly after new alternator, battery and serpentine belt almostbasic 5th gen T4Rs 11 07-10-2023 11:00 PM
question regarding battery reserve capacity (rv) macscac Off Topic 0 06-10-2019 02:37 PM
Exact battery cable lengths for OME replacement with OEM battery oriented posts. Majindan 3rd gen T4Rs 3 11-20-2017 02:57 PM
Multi Battery Isolator and Dual Battery Selector, $60 - Pocatello, ID tjhaf2007 For Sale: Non-T4R Items 17 10-16-2013 11:00 PM
increasing fuel capacity/ secondary battery Tearsfallred4u 3rd gen T4Rs 9 02-25-2012 11:35 AM
