Originally Posted by Rebel_way
Show me you setup please.
My Chinese knockoff 75l dual camera fridge also has 3 protection settings. Shuts down with protection almost immediately when car is not running, while running barely works🤦, and if I put it in emergency override mode while engine is running works fine for a few minutes and than shuts down with low battery warning.
Tested the battery with battery tester and it shows as week battery, so I bet is is time for replacement.
I think I better do dual battery set up, but don't have time and long weekend is coming up.
The protection mode works by sensing the voltage, it's possible you need larger wiring between the battery and the fridge? Might try checking voltage at the plug/fridge when the fridge is running, and then checking it at the battery, see if resistance is dropping it enough to spook the fridge.
The stock 12V outlets have very small wires leading to them, when I put my fridge in I got a socket with 12 gauge wiring and wired it directly to the house battery:
Amazon.com
(with a circuit breaker up by the battery:
Amazon.com )
Here's a pic of my atypical dual battery setup:
I replaced the stock battery tray with a special battery holder for a Grp 34 yellowtop Optima, and then welded on a little perch for the Braille (Deka) B14115 battery. Then wired the car stuff to the Braille, connected the two batteries together with a Blue Sea ACR, and wired various 'house' loads to the yellowtop - the winch, air compressor, fridge, lights.
I've eyeballed lithium battery setups lately, but so far haven't really seen much higher amp-hour capacities in a stock sized bolt-in casing. And the prices are a bit eye watering, but in theory they should outlast 2 or 3 lead acid and/or AGM batteries.
In your situation, I'd just slap a yellowtop in there. It's under $300, it handles starting and is fairly deep cycle. The version that fits in the 4Runner is 48 aH, and again, that ran my Dometic for right around 2 days in Moab last summer.
This summer I was using a Jackery power pack (Christmas present from my wife) run in a pass-through config (it charges from the car when the motor is running, mostly, and the fridge runs off it). Which is probably sweet wretched excessive overkill.
