Old 08-15-2023, 12:14 PM #1
DWilliam DWilliam is offline
DWilliam is on a distinguished road
Getting ready to DIY my first head unit, advice?
I知 installing a Sony CarPlay, and I知 going to order the harness (Metra 70-1761?) from Crutchfield. Not sure if I have a factory amp or not (2002 sR5). Pretty simple? Pop the dash trim off, remove factory amp if I have it? Then plug and play?
Hoping I don稚 get everything off and realize I can稚 finish the job.
DWilliam is offline   Reply With QuoteReply With Quote
Old 08-15-2023, 01:01 PM #2
prybar's Avatar
prybar prybar is offline
prybar is on a distinguished road
prybar's Avatar
Head unit installs are pretty easy. You shouldn't need to mess with the amp unless you're adding your own. Pretty much just connect all the wires and you should be good to go!
'99 Limited, 260k
prybar is offline   Reply With QuoteReply With Quote
Old 08-15-2023, 01:12 PM #3
Thanks! What about adding front door speakers? Pretty straight forward?
Old 08-15-2023, 03:37 PM #4
phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future
You may also need to run a wire to the e-brake for some functionality, you'll need to run a microphone cable and maybe a few other small things...
If the plugs on the back of the stock radio don't match the Metra harness, you have the amp - follow those wires down and remove it. The back of the stock amp has the plugs that match the Metra harness.
Otherwise, no special challenges.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 08-15-2023, 07:05 PM #5
prybar's Avatar
prybar's Avatar
Door speakers can be a bit more involved since they come in all shapes and sizes. The main thing you'll be doing is making sure they fit in the speaker location, and that they don't stick out too far and come in contact with the door panels. Crutchfield is a good resource for this stuff - you can enter your make & model and the website will give you parts that fit and all associated brackets (even if you end up buying from somewhere else). They sell plastic mounting brackets to ensure the speaker sits properly, but I just used a piece of MDF that I cut with a jigsaw.
But, yes - speakers should be pretty straight forward as well!
'99 Limited, 260k
Old 08-15-2023, 08:31 PM #6
poisedforflight poisedforflight is offline
poisedforflight is on a distinguished road
If you're going to do the front door speakers, order a set of these:
Toyota 1996-2002 4Runner 6 1/2" 6.5" Front Door Speaker Adapter – SAK121_55 | eBay
poisedforflight is offline   Reply With QuoteReply With Quote
Old 08-15-2023, 10:11 PM #7
Thanks for the replies. Couple questions:
When wiring tweeters, do I run the existing wire to the crossover then to the new tweeter?
What痴 the best way to wire the parking brake so I can still have full access when it痴 not engaged?
amp , factory , finish , hoping , i知
Head Unit Advice akoda Engines / Suspension / Wheels / Tires / Audio / Accessories 6 12-12-2013 11:51 AM
Getting ready to replace the stock head unit! Anonymous4Runner 4th Gen T4Rs 9 01-12-2012 04:23 PM
WTS: 3rd-Gen ready Pioneer Head Unit Synister Classifieds - buy & sell (no commercial ads please) 0 11-17-2010 06:37 PM
Head unit advice vthokie Engines / Suspension / Wheels / Tires / Audio / Accessories 9 11-14-2010 06:37 PM
question about 3-knob ipod-ready 06 Scion head unit 4route Engines / Suspension / Wheels / Tires / Audio / Accessories 10 12-14-2005 02:24 PM
