Old 08-18-2023, 10:27 PM #1
prybar's Avatar
prybar prybar is offline
prybar is on a distinguished road
prybar's Avatar
Lost Brakes While in Traffic
Howdy All,
Yesterday, as I was going back to work from lunch, I lost my brakes. Luckily, I was stopped at a red light - but all of a sudden, I started rolling forward into the intersection, and had to absolutely mash the brakes to keep from rolling forward. I was able to use the e-brake to get stopped and got a tow back home to figure things out. Before this happened, I didn't notice my brakes going bad.
For reference, it's a '99 Limited, 4wd, California spec, V6.
Symptoms:
-Hard brake pedal after depressing slightly with no resistance
-Hissing when pressing brakes until the pedal firms up
-No power brakes - but I can still stop the truck if I'm moving slowly, like when the truck is off.
-Probably others. If you have any tests to check for other symptoms let me know.
I read on here that some of you cold weather folks have had success by simply replacing the check valve... I was not so lucky. It was about 104 out when this happened, but I figured I'd start with the cheap/easy stuff. New check valve is in, no change. My hose going to the intake manifold is not cracked as far as I can tell.
I suspect the hissing when I press the brakes indicates there's a leak in my brake booster. Does anyone else have any ideas on a fix I can do without replacing the whole unit?
Here's a link to hear the hissing
3rd Gen 4Runner Brake Pedal Hiss - YouTube
If any of you guys have any suggestions on things I could try before spending a lot on a new brake booster, please let me know. Thanks!
'99 Limited, 260k
prybar is offline   Reply With QuoteReply With Quote
Old 08-18-2023, 11:28 PM #2
TucsonMike TucsonMike is offline
TucsonMike is on a distinguished road
Classic sign of brake booster going bad. Both mine and my buddies brake booster hissed and replacing brake booster solved the issue. Hard brake pedal is another sign of bad brake booster. Good luck
MikeM
TucsonMike is offline   Reply With QuoteReply With Quote
Old 08-18-2023, 11:59 PM #3
HiLife HiLife is offline
Been there did that. Same symptoms that you experienced. I though I was gonna wreck the 4r.
I had a backup used vac booster. All good after installing the backup.
Im guessing the rubber bellows in the booster just aged out. Surprising the booster lasted 19+ years.
Old 08-19-2023, 12:38 AM #4
ibob4tacoz's Avatar
ibob4tacoz ibob4tacoz is offline
Real Name: Kent
ibob4tacoz is on a distinguished road
ibob4tacoz's Avatar
Real Name: Kent
+1 to the brake booster calls. The hissing you’re hearing is basically a vacuum leak within the booster.
- '99 4Runner SR5 4WD 5spd
ibob4tacoz is offline   Reply With QuoteReply With Quote
Old 08-19-2023, 02:14 AM #5
prybar's Avatar
prybar's Avatar
Thanks everyone. Consensus online says to just replace the whole booster, but my wallet would prefer to rebuild it or change out the gaskets if that's an option. Has anyone done this before or have any experience in that?
'99 Limited, 260k
Old 08-19-2023, 10:38 PM #6
prybar's Avatar
prybar's Avatar
Update. It was the brake booster. Got a good deal on one from the scrapyard and my brakes feel great. Thanks for your input everyone!
'99 Limited, 260k
Old 10-21-2023, 10:35 PM #7
blaize444 blaize444 is offline
blaize444 is on a distinguished road
that is terrifying glad you're okay.
blaize444 is offline   Reply With QuoteReply With Quote
brake , brakes , check , happened , hissing
Lost all brakes today Flybynight 4th Gen T4Rs 1 12-21-2021 05:17 PM
Lost ma Brakes today giguchan 3rd gen T4Rs 11 07-21-2021 01:57 PM
Don’t hear electric motor and brakes feel very mushy in traffic Dirtrider216 4th Gen T4Rs 12 01-14-2020 01:11 PM
lost my brakes! Hapeacres 4th Gen T4Rs 4 08-11-2019 12:24 PM
So I almost got raped by the Dealer today....brakes brakes brakes. DizzyV6P 5th gen T4Rs 36 04-28-2015 11:23 PM
