Old 08-28-2023, 02:53 PM #1
WrenchTech's Avatar
WrenchTech WrenchTech is offline
Real Name: Matt S.
WrenchTech is on a distinguished road
WrenchTech's Avatar
Real Name: Matt S.
Key Stuck in Ignition
The key will not come out of the ignition lock cylinder, and it won’t turn all the way to the locking position on a friend’s 2002 SR5 Sport Edition. The auto transmission shifter recently developed some problems are they related? Does the shifter need to be in park for the key to be released? On my 99 SR5 The key comes out, anytime, running, in drive, it doesn’t matter. I’m thinking maybe that’s not normal. So I don’t know what the normal condition is for my friend’s 2002. Any ideas?
1999 SR5 3.4 auto, Horizon Blue Metalic 8N1, blue cloth, steel Daytona wheels, 265/75/16 AT tires, rear heat, A/C, sunroof, electric locking rear dif.
WrenchTech is offline   Reply With QuoteReply With Quote
Old 08-28-2023, 03:16 PM #2
ninethings ninethings is offline
Real Name: Tim
ninethings will become famous soon enough
Real Name: Tim
it needs to be in park. Is the wheel locked? Sometimes have to pull one way or another on the wheel to free up the lock cylinder
<a href=https://blogger.googleusercontent.com/img/b/R29vZ2xl/AVvXsEhRUBHdN4dX3N-MZqnf4MmbxaF1QVQ8kLoGcbvEX3SNwSyV_geqoX9F5LACC8BWf7UQIBzi5AC5qHBgksRfky-s3P1k9Pp-70LTMpPzK__f2bK2f30sbQq_zRuN3Cqwx93feDQ9Ndb2dQav6nodFdYVRSNBnDFeeSfFIiVfUq0VyQ3yYr93Gg0IjfTdAO0/s320/IMG_4239.jpeg target=_blank>https://blogger.googleusercontent.co.../IMG_4239.jpeg</a>
ninethings is offline   Reply With QuoteReply With Quote
Old 08-28-2023, 05:06 PM #3
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
Try having him put the shifter in neutral, start the truck, and then try to put it back in park. Then he needs to push forward on the shifter while turning the key. If his shifter is super loose, it's likely his bushings. If it's nice and tight, then it's probably the Park switch.
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 08-28-2023, 05:23 PM #4
Twisted Sid's Avatar
Twisted Sid Twisted Sid is offline
Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about
Your '99 releasing the key at anytime, isn't normal.
'99 4Runner SR5: 5VZ, 2wd, AT, 400k+ club
'94 Pickup: 2wd, 22RE, 5spd, (3RZ swap in progress)
Front: Total Chaos Uniball Kit, Fox 2.5 8'' coilover
Rear: Deaver F67 Leaf Springs, Fox 2.0 14'' Reservoir Shocks, E-locker Axle 4.88 Gears 33x10.5 BFG ATs
Twisted Sid is offline   Reply With QuoteReply With Quote
Old 08-28-2023, 09:53 PM #5
WrenchTech's Avatar
Real Name: Matt S.
WrenchTech's Avatar
Real Name: Matt S.
It’s the shifter most likely. It got damaged recently and now it’s pretty loose.
Old 08-30-2023, 08:09 AM #6
Brutus H Brutus H is offline
Brutus H is on a distinguished road
Mine does that too. I usually just turn the key back on then move my shifter, which is very loose, back and forth, maybe a couple times till it come out. Until it becomes a real problem, I'm not planning on fixing it.
Brutus H is offline   Reply With QuoteReply With Quote
Old 08-30-2023, 11:14 AM #7
prybar's Avatar
prybar prybar is offline
prybar is on a distinguished road
prybar's Avatar
Yes, not "normal" from factory, but it's a normal thing that happens with time (at least on these Toyotas). Mine does it, my buddy's does it, and so does his 20 year-old Camry. I actually love being able to take the key out while it's running, it's a pretty handy "failure."
'99 Limited, 260k
prybar is offline   Reply With QuoteReply With Quote
Old 08-30-2023, 04:02 PM #8
WrenchTech's Avatar
Real Name: Matt S.
WrenchTech's Avatar
Real Name: Matt S.
Thanks. That’s what we are doing right now too.
There is a self-serve wrecking yard near us that has a 2002. We will go over there and see if we can get the parts that we need.
Old 09-01-2023, 01:12 AM #9
JBurt's Avatar
JBurt JBurt is offline
Real Name: Jeff
JBurt has a spectacular aura about JBurt has a spectacular aura about
JBurt's Avatar
Real Name: Jeff
You probably definitely need to replace your shifter bushings. They are cheap. Here's a thread with part numbers and a write up:
Loose Shifter? - Replace your shifter bushings! - Write up with pictures
97 SR5 4runner: 2" OME Lift, rear E-Locker, 231mm Tundra Brakes, 203K, B&M 70264 Tranny Cooler, Duratracs
Build
JBurt is offline   Reply With QuoteReply With Quote
Old 09-01-2023, 10:26 PM #10
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
I've got something better than a write-up. Even though write-ups are super helpful, their limitation is they are 2-dimensional. I'll take a 3-dimensional video over a write-up any day. But, I am a bit biased since I run a YouTube channel. I actually used the write-up you linked as research to make the video below. The bonus with my video is I also include how to replace the transfer case shifter bushing.
But, Ramon makes good write-ups, and if you're into write-ups, his is a good one to use.
OP, the fact you can't get out of park is definitely related to the shifter. I just had this issue with my 98 3rd Gen and new shifter bushings fixed the issue.
Old 09-01-2023, 11:31 PM #11
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
Yep mine does this sometimes. No big deal.
Jakeepoo3 is offline   Reply With QuoteReply With Quote
friend’s , key , normal , shifter , sr5
Key stuck in ignition fix TejasRunner01 3rd gen T4Rs 32 03-10-2023 04:40 PM
Key stuck in ignition AGAIN cantaloop 3rd gen T4Rs 14 01-18-2017 05:05 PM
HELP!!! My key keeps getting stuck in the ignition 96BladeRunner 3rd gen T4Rs 9 06-03-2015 09:40 AM
Key stuck in ignition!!!!! Bm14_ryod 3rd gen T4Rs 11 10-17-2013 01:37 PM
Ignition Stuck on 98 4Runner Dawg 3rd gen T4Rs 2 04-09-2011 01:50 PM
