Originally Posted by Jakeepoo3
Sounds like an outer CV joint. It's easy to check. The inner or outer joint don't seal tight. You should have about an eighth inch of in and out play. The problem would be lateral play. Grab the axle shaft near each joint and pull and jerk on it real hard. There should be no play.
Last I checked, I have barely any play in the axle itself, but I can pull the cover in and out about 1/8" from where it connects to diff on both sides. I'll try again today and it give it a harder pull.
I just installed the new rack and I'm afraid to drive it anywhere prior to my alignment on Monday. Im not sure that the clunking is coming from tie-rods, rack etc.. but I don't want to chance it with the clunk. I matched marked the tie-rods, but what if they're off and 1/8' or so, would this cause binding in the rack? I don't want to destroy anything in the new rack. I did however have the clunk prior to installing the rack, which I thought the rack would fix
